Old 02-03-2007, 10:01 PM
BaW BaW is offline
Dealer : Crown Toyota Scion
Last Online: 05-07-2009 01:20 AM
BaW is on a distinguished road.
BaW's Photo Albums
Default Oil Synthetic or Non Syn?
Well I change my oil every 5k miles sometimes i got over just a little bit like about 700 miles, but my problems is i am not using synthetic oil and i dont know if i should change to it now, i own a 2001 tundra v8,
I dont really want to go to synthetic anyways because i heard of the early tundras getting oil leaks
I am find staying with my reg oil but which one should i got with, i been using mobil 1 is that a really good brand or should i go with something else?
and also for my oil filter i been using the new K&N oil kilter works great.
also i am about 75,000 miles on my truck my next oil change is coming up soon
Old 02-03-2007, 11:49 PM
MtTrout's Avatar
Dealer : Kalispell Toyota
2007 Toyota Sequoia
Last Online: 11-16-2009 05:52 PM
MtTrout is on a distinguished road.
MtTrout's Photo Albums
Default Re: Oil Synthetic or Non Syn?
If you click on the "search" link on the forum menu bar and then go to the advanced search, then put "oil" in the advanced search box and check title search. You will find countless opinions on oil types, change intervals, etc...
Old 02-03-2007, 11:58 PM
CHINKinatundra's Avatar
Dealer : Red McCombs Toyota
2002 Toyota Tundra
Last Online: 08-10-2009 10:24 AM
Images: 2
CHINKinatundra is on a distinguished road.
Send a message via MSN to CHINKinatundra CHINKinatundra's Photo Albums
stay with mobil 1. i switched to synthetic engine oil in december. no leaks or any problems. i also just siwtched to synthetic transmission fluid. works great so far! i'm probably going to switch to synthetic fluid for the differential as well.
Old 02-04-2007, 05:07 PM
Dealer : Camelback Toyota Scion
Last Online: 07-29-2007 04:05 PM
kev009 is on a distinguished road.
Send a message via ICQ to kev009 Send a message via AIM to kev009 Send a message via MSN to kev009 Send a message via Yahoo to kev009 Send a message via Skype™ to kev009 kev009's Photo Albums
What kind of ATF are you using? Did you notice any change in transmission performance with the change?
Old 02-04-2007, 05:16 PM
jasbus's Avatar
Dealer : Toyota Scion of Winter Haven
2003 Toyota Tundra
Last Online: Today 12:53 PM
jasbus is on a distinguished road.
jasbus's Photo Albums
I believe that the Toyota ATF is full syn, someone correct me if I'm wrong...
I run Mobil 1 in everything I own, I mean everything. But, as long as you change your oil often, your ok with even the cheapy stuff...
My bro-in-law runs a trucking company, they run dino in all their trucks, and he thinks I'm crazy for spending the extra on syn, and changing the oil so often on top of that... They run tests for Valvoline in their trucks, he swears you don't need syn.
Blacked out 2003 Limited 4X4 Access Cab with TRD Off-Road Package Debadged
2.5" Fabtech suspension lift
3" body lift
Old 02-04-2007, 07:35 PM
Buckeyefan's Avatar
Dealer : Tansky Sawmill Toyota Scion
Last Online: 07-22-2009 02:26 PM
Buckeyefan is on a distinguished road.
Send a message via MSN to Buckeyefan Send a message via Yahoo to Buckeyefan Buckeyefan's Photo Albums
I used Mobil 1 Syn in my '98 F150 every 10,000 miles, and the engine still purrs at 139,000. I can only hope my '06 DC does as well. The small amount extra for the syn is worth its weight in gold. $49 at Walmart for a full syn oil change. That's less than a tank of gas.
2006 DC SR5 V8 4x4 Phantom Gray Metallic
2003 Honda Pilot EXL 4WD Black
http://i19.photobucket.com/albums/b1...hrack001-2.jpg
Old 02-04-2007, 11:43 PM
tundo's Avatar
Dealer : Findlay Toyota Flagstaff
2000 Toyota Tundra,
- Other - 1981 Ford Courier,
2001 Toyota Tundra Ivan Stewart/ Green
Last Online: 05-04-2008 08:08 PM
tundo is on a distinguished road.
tundo's Photo Albums
Agreed. On top of that you save on gas and it keeps your engine cleaner. When I switched to synthetic I ran it for 1000 miles on the first change, drained it (since it was mixed with regular oil) and am now on my second batch of Mobil 1. I buy the 5 quart Mobil 1 from Walmart ($23.00) plus an extra quart (tundras require 6 quarts, another $6.00), and finally a filter ($4.00). Figure right around $33.00 if you change it yourself. When you drive your truck you will notice the difference, there seems to be no loss in friction HP. The only thing I had to do different is tighten the oil filter a little tighter with synthetic. I have full intentions of running synthetic in all my vehicles from here on out
Ryan
Old 02-05-2007, 12:27 AM
Dealer : Toyota of Palo Alto
2007 Toyota Tundra 5.7l DC Desert Sand
Last Online: 04-22-2009 10:51 PM
MJScore is on a distinguished road.
MJScore's Photo Albums
I've run Mobil 1 in my 2000 Tundra as soon as I broke it in. I am now on 322,000 miles with no engine work at all. I highly recommend Mobil 1 and will be using it in my new Tundra when it arrives.
Old 02-05-2007, 06:57 AM
Dealer : Gene Reed Toyota
Last Online: 11-15-2008 12:28 PM
cubcake1 is on a distinguished road.
cubcake1's Photo Albums
Originally Posted by MJScore View Post
I've run Mobil 1 in my 2000 Tundra as soon as I broke it in. I am now on 322,000 miles with no engine work at all. I highly recommend Mmobil 1 and will be using it in my new Tundra when it arrives.
322,000 miles
Old 02-05-2007, 07:37 AM
RitcheyRch's Avatar
Fellow Tundra Owner
Dealer : Frontier Toyota
2002 Toyota Tundra
Last Online: Today 12:01 AM
Images: 2
RitcheyRch is on a distinguished road.
Send a message via AIM to RitcheyRch RitcheyRch's Photo Albums
I use Mobil 1 in the engine, transmission and rear end on my Tundra only because use the vehicle for towing the boat on occasion. Agree, is a far superior oil to the dino based stuff but know of many Honda's, Acura's and Toyota's with over 200K miles that have strictly used the old dino based oils with no issues.
All boils down to preference. I prefer Castol GTX in all my other vechicles but will stick with Mobil 1 syntethic in the Tundra.
Old 02-05-2007, 07:56 AM
2002 Toyota Tundra
Images: 2
Mobil 1's syn. ATF is a MERCON/DEXRON Compatible fluid, so it's ok to use in your 2001.
Old 02-05-2007, 10:21 AM
The Phoenix's Avatar
Moderator
Last Online: 11-13-2009 03:17 PM
Images: 2
The Phoenix's Photo Albums
No timing belt change? Ticking time bomb right there
Old 02-05-2007, 08:17 PM
Buckeyefan's Avatar
Exclamation Here's an eye opener
I just called my dealer and talked to the service manager. I told him I religiously used Mobile 1 Syn in my F150 and it ran perfectly. He said he's found over the years those who switch to synthetics in Toyota vehicles seem to have more oil leaks than those who stick to "Toyota oil," which he said is Mobile 1 standard oil 5W30. This is interesting. Why would synthetic oil cause leaks in Toyotas over standard oil?
For those who get their oil changed at the dealership, do they offer synthetics, or recommend them? I bet Mobile Oil would be interested in this (if it's true). Synthetic oil would bring in more cash for the service department, so I can't see why he'd be B.S.'ing me.
Old 02-05-2007, 08:53 PM
yspert's Avatar
Dealer : Rice Toyota
Last Online: 10-30-2009 10:49 PM
yspert is on a distinguished road.
yspert's Photo Albums
Talking Re: Oil Synthetic or Non Syn?
One thing to always remember about engine oil. Clean oil is good! The
junk that gets into the oil is what causes problems. Not what type.
Oil damages seals?
No oil company will allow that to happen or be proved true. What damages seals?
Again, the junk that gets into the oil.
Does oil cause sludge? All oils cause sludge after a certain point.
Would you buy used oil? yspert
Graduated from Y to Z status.
Old 02-05-2007, 11:06 PM
Buckeyefan's Avatar
That's one other topic I haven't been up on. Which Toyota vehicles had the engine sludge issues? Did they ever determine what was causing it? I would think a synthetic would be less likely to sludge. Any oil experts in the house?
Oil Filter Change nhparrot Engine & Drivetrain 10 06-07-2009 07:15 PM
synthetic oils - yes or no? nhparrot Engine & Drivetrain 21 01-29-2008 05:25 PM
Which BRAND of OIL? nhparrot Engine & Drivetrain 9 10-29-2007 01:43 PM
Best oil to run in the 4.7 Tundra? SMOKEATR Engine & Drivetrain 69 03-22-2007 06:33 PM
GEORGE! or anyone else..Whats The Best "DINO" Oil nhparrot Engine & Drivetrain 0 03-28-2002 04:21 PM
