  2 links from elsewhere to this Post. Click to view. #16 (permalink)
Old 02-24-2007, 12:35 AM
Dealer : Hansel Toyota Scion
Last Online: 09-12-2007 01:24 AM
MGTMike is on a distinguished road.
MGTMike's Photo Albums
Default Re: New Scan Gauge install thread
Originally Posted by skipo View Post
the angle bracket the gauge is mounted to is upside down that is why the wire is coming out the side instead of the back I need another standoff to get it below the mirror and right side up and then bend the bracket so the angle is the same as the mirror i tried to mount it in the upright position but you cant see the readout
Skip
Skipo,
The BlendMount should fit on top of the mirror even with the console there. Did you move the linkage down utilizing the windshield pivot?
http://www.mgtmotorsports.com/sgComp.html
  #17 (permalink)
Old 02-24-2007, 08:36 PM
benbeaux's Avatar
Dealer : Toyota of Richardson
2006 Toyota Avalon Desert Sand Mica,
2006 Toyota Tundra Desert Sand Mica DC,
- Other - 2007 Suzuki Burgman
Last Online: Yesterday 07:33 PM
Images: 2
benbeaux is on a distinguished road.
benbeaux's Photo Albums
Originally Posted by Cascadia View Post
I posted this earlier on another thread dealing with Scan Gauge readings, but I thought I would do a new thread for those looking for an easy way to mount it but might not look at that other post.
I just finished installing my Scan Gauge. For those of you who do not use your ashtray, this is a simple way to mount it with the cable not exposed. I used a piece of plywood (same thickness as the ashtray rails), and another small block of wood. I have posted the pics in my gallery.
http://www.tundrasolutions.com/photo...0/ppuser/29139
I cut the front of the mounting base at a 35 degree angle, and the Scan gauge is velocroed to it. The nice part is, it can be easily slid out at any time and the ashetray put back in. I just thought someone else might like to use this idea.
I did this:
  #18 (permalink)
Old 02-24-2007, 09:41 PM
5 Speed's Avatar
Dealer : Longo Toyota
Last Online: Today 11:46 AM
Images: 19
5 Speed will become famous soon enough.
5 Speed's Photo Albums
With the single DIN sony, here is where I mounted mine, note the small level, I have a 4WheelCamper on back and this helps when setting up and keeping the bed level
  #19 (permalink)
Old 03-25-2007, 07:55 AM
Hispeed's Avatar
Dealer : Big Two Toyota & Scion of Chandler
Last Online: Yesterday 10:43 AM
Images: 31
Hispeed is on a distinguished road.
Hispeed's Photo Albums
After staring at my dash for several months, here is how I decided to install my Scan Gauge II.
Not one hole has to be drilled in your Tundra.
It's a real easy cable run from the OBD connector to the display unit.
You can knock this project out in under a hour.
Scan Gauge visibility is great from my seat height. All instrument cluster annunciator lights are visible.
Materials: 7 1/2 inches of 3/4" x 1/16" flat aluminum stock.
3 to 4 inches of 1" x 1/16" angle aluminum stock.
Two 1/8" aluminum pop rivets (or epoxy, 5200, or other adhesive).
Felt or plastic sticky backed pads
Velco
Tools: Hacksaw
Dremel with cutting wheel,
Vicegrips
File
Drill with 1/8" bit
Pop Riveter
Using your dremel or hacksaw, cut a 7 1/2 " length of flat aluminum stock (all measurements are approximate). Clean up the rough edges with your file as you go.
Point the drivers side A/C vent up. Slide the flat stock in the gap between the vent and the dash. On my 2000 model, There is a rib that is 3/4" above the bottom of the duct. With the vent pointed up you can slide your flat stock right into that gap beneath the rib. It should go in about 3" and not go past the vent shut off valve. (It fits like it was made to go there).
With the piece still in the vent, mark it where you want to make the bend.
Remove the piece and make a 90 degree bend.
Slide your piece back into the vent. You'll probably see that it kind of droops in relation to the instrument pod. Remove your piece and using the vice grips, put a little twist into the part that goes into the vent. Refit and check. Bend some more as necessary. About 10-15 degrees of twist should do it. DON'T TRY TO BEND IT IN THE DUCT. SOMETHING WILL BREAK.
Cut your 1" aluminum angle stock 3 to 4" in length. Take the angle piece,
3/4" flat piece, and your Scan Gauge. Dry fit them all together, marking where
you want the rivets to go, and where the notch on the back needs to be cut for the cable to plug into the Scan Gauge.
(Initially, I tried plugging into the end of the Scan Gauge but every time I adjusted the steering wheel, it bumped the SG cable & knocked the whole thing out of whack. Hence the notch).
Once everything is lined up to your satisfaction, clamp the two pieces together and drill two 1/8" holes and then rivet them together or, if using an adhesive, glue em, clamp em, and call it a day.
When the 2 parts are securely fastened together, take your handy dremel tool with cut off wheel
and cut out the notch for the rear cable plug. Fit and attach the velcro to the front face of the mount and the Scan Gauge.
(I used super industrial strength Velcro).
Stick some felt padding on the inside radius of the 90 degree bend to keep from chaffing a hole in your dash.
Run the cable up behind the lower dash panel and out the gap between the steering column and the dash.
Plug the cable in, slide the mount into the A/C vent under the rib and the and you're good to go!
New Scan Gauge install thread-sg-01.jpg   New Scan Gauge install thread-sg-02.jpg   New Scan Gauge install thread-sg-03.jpg   New Scan Gauge install thread-sg-04.jpg   New Scan Gauge install thread-sg-05.jpg   New Scan Gauge install thread-sg-07b.jpg
New Scan Gauge install thread-sg-09a.jpg   New Scan Gauge install thread-sg-10.jpg   New Scan Gauge install thread-sg-11.jpg
'00 Thunder Gray Ltd 4wd TRD Oak Leather Interior
Roll & Lock Tonneau
All LED's Inside and Out
'05 DC center console installed
Map Light Mod
Pwr Outlet Mod
Ignition Chime Override Mod
Arm Rest Mod
Dual Magellan GPS's
ScanGauge II
Hurricanes Ivan and Dennis Survivor
Bill and Scooter say: "Tundras' Rock!"
  #20 (permalink)
Old 03-25-2007, 04:06 PM
Dana_15's Avatar
Dealer : Gale Toyota Scion
2007 Toyota Tundra,
2005 Toyota 4Runner
Last Online: 01-29-2010 10:47 AM
Dana_15 has blessed us with their presence. Dana_15 has blessed us with their presence. Dana_15 has blessed us with their presence. Dana_15 has blessed us with their presence.
Dana_15's Photo Albums
^^^^Nice install, I might get one soon myself, nice cats too
  #21 (permalink)
Old 10-11-2008, 09:47 AM
Dealer : Stephen Wade Toyota
Last Online: 01-22-2010 03:48 AM
Images: 67
trekfan101 is on a distinguished road.
trekfan101's Photo Albums
I have seen this install that was done by "Hispeed" and there was one other that i saw on a Tacoma from another site that had it installed in the steering column. i recently installed mine this way and decided to make a little write up to help anyone else that might want to do the same thing.
I hope it helps at least one person out there.
  #22 (permalink)
Old 10-11-2008, 10:49 AM
USAFTUNDRA's Avatar
Dealer : Northcutt Toyota
2005 Toyota Tundra,
- Other - 2006 Honda CRV SE
Last Online: 12-23-2009 06:12 PM
Images: 107
USAFTUNDRA will become famous soon enough. USAFTUNDRA will become famous soon enough.
USAFTUNDRA's Photo Albums
Nice write up and nice install. Thanks for posting your idea. I really considered doing something similar but on 2005 I didn't want to put a hole in the steering column. But baring that I think your install is in the top 3 or 4 ideas for our trucks. Great Job and great presentation!
  #23 (permalink)
Old 10-11-2008, 12:18 PM
BAD BONEZ BJ's Avatar
AKA blackmbj
Dealer : Priority Toyota
1993 Toyota Truck,
2006 Toyota Sienna XLE in Pear White,
2003 Toyota Tundra AC Limited 4WD,
1998 Toyota 4Runner Trade-In,
2004 Toyota Sienna Trade-In,
2004 Toyota Prius Trade-In,
2006 Toyota Highlander HV Trade-In,
1998 Toyota Celica Sold,
- Other - '81 Tercel - Sold
Last Online: 12-07-2009 11:58 PM
Images: 570
BAD BONEZ BJ will become famous soon enough. BAD BONEZ BJ will become famous soon enough.
Send a message via AIM to BAD BONEZ BJ BAD BONEZ BJ's Photo Albums My eBay
I used Highspeed's idea, and slightly modified it as mine is screwed in. The wire you see running past it is the MP3 player connector to the sterio.
2003 Tundra 4.7L V8 Access Cab Limited 4WD
w/ all factory packages, Black Onyx 202-rebadged. was stock 31K on 5/9/05, now 56K
Performance: DYNOed at 208 HP and 272 TQ
* UNICHIP (broken) * AEM Brute Force Intake * AEM DryFlow Filter * K&N DryCharger * AirRaid TBS * JBA Titanium-Ceramic Headers * JBA Y-Pipe * Gibson CAT-Back Dual Extreme Exhaust * PulseStar Pulse Plugs * Fitch Fuel Catalyst System * Optima D35 Yellow Top * Argus Battery Bug * Fumoto F103N Oil Drain Valve * RP Oils *
Exterior:
* Extang Full-Tilt Tonneau * Bedrug * Topline Tailgate Step * Mr. Gille Upper & Lower Billet Grille * WAAG Bumper Guards, front & rear * HT Side Step Nerf Bars * AVS Hood Protector * WeatherTech Vent Shades * JDM Black Taillights * TurnSmart Solar-power Mirror Turn-Signals * Altec 48" Line-of-Fire LED Light Kit * Altec 53" Screamer Amber Side Marker LED * PIAA Backup/Work Lights * 35 % Tinting * Bully LED Third Brake/Cargo Light *
Interior:
* Gentex Auto Dimming Compass/Temp Rear View * Garmin's Nuvi 660 GPS * Scan Guage II * Passport SR7 Radar/laser shifter *
Wheels/Tires:
* Moto Metal M0951 Gloss Black 17 in. Alloys * SpiderTrax 1.25" Wheel Spacers * Goodyear Fortera TripleTred radials P275/60R17 *
Suspension:
* Bilstein HD Shocks, F&R * Hellwig Rear Sway Bar & Helper Springs * TCS Poly Steering Rack Bushings * Wheeler's Front Sway Bar Bushings * Timbren SES Kit, Front & Rear *
Brakes:
* TRD Big Brake Kit (front) *
BAD BONEZ BJ
  #24 (permalink)
Old 11-25-2008, 02:40 AM
RCsTundra's Avatar
Dealer : Fred Haas Toyota Country
2006 Toyota Tundra,
- Other -- 2001 BMW (E39)
Last Online: Yesterday 11:25 PM
Images: 28
RCsTundra is a splendid one to behold. RCsTundra is a splendid one to behold.
RCsTundra's Photo Albums
- 2001 Tundra AC Limited - SOLD 2/8/09
- 2006 Tundra DC SR5 - PURCHASED 12/17/09 <--- CLICK
WANT TO BUY:
- 1st gen Tundra DC OEM all weather mats <--- CLICK
- 1st gen Tundra DC bedrail little plastic cover <--- CLICK
  #25 (permalink)
Old 11-25-2008, 07:07 PM
dosequis driver's Avatar
Dealer : Cobb County Toyota Scion
2006 Toyota Tundra SR5 DC
Last Online: 10-02-2009 07:32 PM
dosequis driver is on a distinguished road.
dosequis driver's Photo Albums
Exterior Changes: 18" BBS wheels * TRD sport grille * color-keyed rear bumper, mirrors, side body moldings, front bumper applique * fully debadged * Ground Force lowering shackles * LiftLips wheel wheel liners * Avery Stoneguard clear bra * ARE Z-Series shell with limo tint & keyless lock * Weather tight rear bed * Hoppy EasyLift tailgate assist. Interior Changes/Electronics: Aftermarket leather * Front window tint * Gentex mirror * Wireless back-up camera * GPS slide-out mount * ScanGuage II overhead console mount * Concealed CB in center console * Extra DC power outlets inside center console * USA Spec iPod adapter
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tundra/89065-new-scan-gauge-install-thread/
Posted By For Type Date
Got my Scanguage - whoohoo! - GasSavers This thread Refback 06-29-2007 06:37 PM
Got my Scanguage - whoohoo! - GasSavers This thread Refback 06-19-2007 02:04 AM
Extending Automatic Transmission Life Transdude Engine & Drivetrain 218 12-13-2009 10:34 PM
Re: Fuel Gauge Works Intermittently garyjerdee 4Runner 2 11-17-2006 01:21 AM
Tacoma: Coolant gauge install obscurotron Engine & Drivetrain 17 02-02-2006 03:57 PM
Transmission Temp Gauge (what & where) BaseCamp Towing 26 01-23-2006 12:58 PM
Gauge Install Help!!!! OCTundraTRD Electrical & Computer Systems 4 01-17-2004 05:35 PM
