Old 02-20-2007, 11:44 AM
MIKEGOUGH1's Avatar
Dealer : Springhill Toyota Scion
2008 Toyota Tundra 5.7L SR5 Crew Max
Last Online: 10-21-2009 08:50 AM
Images: 2
MIKEGOUGH1 is on a distinguished road.
MIKEGOUGH1's Photo Albums
Default Tire size and speedometer change
I am changing tires from the Dunlop P265/65/17 to the Michelin 265/70/17. The Michelin is overall about 1.5" larger in diameter. Is this going to make much difference in the speedometer reading?
Mike
2008 Tundra Crew Max SR5 , Pyrite Mica, SS Steps, Fender Flares , 20" Limited wheels w/305/50/20 tires,
Alarm system, Sirius radio
Old 02-20-2007, 12:35 PM
The Phoenix's Avatar
Moderator
Last Online: 11-06-2009 02:51 PM
Images: 2
The Phoenix's Photo Albums
Default Re: Tire size and speedometer change
Stock Size P265/65R17
Sidewall: 6.8in
Radius: 15.3in
Diameter: 30.6in
Circumfrence: 96.0in
Revs/mi: 660.0
New Tire Size P265/70R17
Sidewall: 7.3in
Radius: 15.8in
Diameter: 31.6
Circumfrence: 99.3in
Revs/mi: 638.0
Speedometer reading with a non-stock tire is 3.4% too slow.
When your speedometer reads 60mph, you are actually traveling 62.0mph
Old 02-20-2007, 12:39 PM
Dealer : Magnussen Auburn Toyota
Last Online: 09-29-2007 12:54 AM
Tund-doublecab-4x4 is on a distinguished road.
Tund-doublecab-4x4's Photo Albums
I was shopping tires this last weekend and I was looking at the 275/70r 17 and the guy said it would change my speedo. It would be about 4-6 mph off (would read slower than actual speed).
Can anyone verify this info.?
Also, can I fit this tire on a stock 06 DC 4X4 without rub?
1991 4x4 SR5 V6 extra-cab truck 150k in 3 yrs. (sold)
1997 4x4 4runner 150k (traded in)
2006 4x4 Tundra 2x-cab limited
Old 02-20-2007, 02:52 PM
TheGryme's Avatar
Supportive Supporter
Dealer : Valley-Hi Toyota
2004 Toyota Tundra,
- Other - 1992 Toyota 4Runner
Last Online: 11-06-2009 11:42 PM
Images: 23
TheGryme will become famous soon enough.
TheGryme's Photo Albums
Yup.....I run Nitto TerraGrapplers that are bigger than stock and my speedo is off by about 3 MPH and the ODO is off about 5%....I've confirmed this with my GPS unit....It doesn't seem to effect anything badly....(shifting, cruise, etc.)
TheGryme Ummmm Beer Good.....Whiskey Better!
'04 Tundra DC
Grey....V8 SR5 4X4 TRD Off Road Suspension, LSD, Towing Package, Toyo Open Country A/T 265 75 16 ~ 8 Ply's, Magnaflowed (w/ Secret AirBox Mods!), UNIChipped, True~Flowed, DeBadged, ScanGaged, XM'ed.....Yeah!
'92 4Runner
Black, V6, Downey / Rancho suspension F&R, 3 inch sus lift, 1 inch body lift, SAW T-Barz, 4:88's, ARB (rear), 32X12.50 BS Dualers on AR 8X15 Wheelz, Power Slots and Pads, Downey headers, MagnaFlo Muff, K&N FIPK, Ported heads, 1 piece stainless valves...way too much money in it!
'04 YZ250F
Dr.D Header and Can, JD Jetting, P38 AP, UNI Flame Proof Air Filter, No Back Fire Screen, Carbon Fiber Carb Heat Shield, Renthals, ASV Controls....
'87 Nissan Pathfinder......gone but not forgotten.
Old 02-20-2007, 11:48 PM
Moderator
Images: 2
Assuming you have P265/65R17 as stock, the following applies. You should not have any rubbing issues, but possible if the suspension is compressed (off-roading), but nothing to worry about in my opinion.
Sidewall: 6.8in
Radius: 15.3in
Diameter: 30.6in
Revs/mi: 660.0
New Tire Size P275/70R17
Sidewall: 7.6in
Radius: 16.1in
Diameter: 32.2
Circumfrence: 101.0in
Revs/mi: 627.0
Speedometer reading with a non-stock tire is 5.2% too slow.
When your speedometer reads 60mph, you are actually traveling 63.1mph
Old 02-20-2007, 11:52 PM
integraGSR's Avatar
2005 Toyota Tundra
Last Online: 11-06-2009 11:58 PM
Images: 14
integraGSR will become famous soon enough.
Send a message via AIM to integraGSR integraGSR's Photo Albums My eBay
after replacing my tires with 265/75/16 from 265/70/16 my GPS now tells me that i am going 3 MPH faster than the gauge reads.
05 Salsa Red Pearl DC
01 Honda Civic
95 Acura Integra
Old 02-21-2007, 12:11 AM
willy's Avatar
Dealer : Mic Mac Motors
- Other - '41 Chevy 1/2 ton,
2007 Toyota Tundra DC 4WD LB
Last Online: 09-06-2009 09:10 AM
willy will become famous soon enough.
willy's Photo Albums
Grab a GPS and see for yourself. Mine didn't change much at all.
Old 02-21-2007, 12:37 AM
JustBNme's Avatar
Dealer : Lakeside Toyota
2006 Toyota Tundra DblCab Limited 2WD,
1994 Toyota Camry SE V6,
- Other - `95 Caddy Fleetwood
JustBNme is on a distinguished road.
JustBNme's Photo Albums
There's plenty of tire size calculators "out there", but this one will let you compare several at once. You'll still need input from others here about rubbing issues, but the tire and speedometer variances are just factors of math and measures. It also wouldn't surprise me if someone else posts a link to a better calculator, since that's one I found with only a quick look around.
Old 04-06-2007, 10:50 PM
Dealer : Claremont Toyota Scion
Last Online: 12-15-2008 12:46 AM
geomoto is on a distinguished road.
geomoto's Photo Albums
So the two dollar question is. Is there a way to correct it?
Old 04-06-2007, 11:45 PM
rsayloriii's Avatar
Dealer : San Marcos Toyota Scion
Last Online: 10-24-2009 11:59 AM
rsayloriii is on a distinguished road.
rsayloriii's Photo Albums
SuperLift TruSpeed Speedometer Recalibrator
Old 04-07-2007, 04:30 AM
DesertMatt760's Avatar
DesertMatt760
Dealer : I-10 Toyota Scion
2005 Toyota Tundra
Last Online: 10-17-2009 04:26 PM
Images: 15
DesertMatt760 is on a distinguished road.
Send a message via AIM to DesertMatt760 Send a message via Yahoo to DesertMatt760 DesertMatt760's Photo Albums
Well, I just did i calculation from my old tires to my new ones, seems now that my truck will read that i am doing only 57MPH when I am really doing 60MPH. my 05 had the 16 inch BFG tires and those off road rims. I think they were 265/70/R16 if I remember right. I now have a 285 tire with 22 inch rims. so my new size is now 285/45R22 Website shows i am about 5% off. not much. Consider the benefit. If you ever wanna sell your Tundy... God forbid, then your odometer will show lower mileage then what is really on the truck! The bad thing... if you are on the freeway doing a bit over 74MPH according to the speedometer, the cop may actualy get you going at maybe 78-80 MPH since the faster you drive on bigger tires, the more the ratio goes up for actual speed, so you may get a speeding ticket, just a heads up!! also with my 285 tire on regular suspension and no lift, i clear fine and dont rub, if i have a lil more weight in the truck say like a passenger, and i do a fast u turn, i occasianlly hear a slight rub, very slight, not enough to even cause a problem!!
Old 04-09-2007, 11:42 AM
05regcab's Avatar
Dealer : Metro Toyota
2005 Toyota Tundra
Last Online: 07-06-2009 01:53 PM
05regcab is on a distinguished road.
05regcab's Photo Albums
Good news is, if you put 100,000 miles on you truck, the odometer will only show 97,000 miles.
Old 04-09-2007, 12:18 PM
H2O_MAN's Avatar
Obama lies ~ the economy dies
Dealer : Heyward Allen Toyota Scion
2002 Toyota Tundra 4WD long bed V8 SR5
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Yep, my T100 showed 208K when I sold it but the taller than stock tires hid about 8K.
Old 04-09-2007, 12:50 PM
KurtH's Avatar
Dealer : Milton Martin Toyota
2005 Toyota Tundra
Last Online: 10-16-2009 08:56 PM
KurtH is on a distinguished road.
KurtH's Photo Albums
H20, do ya mind if I swipe the billary pic? That's great.
2005 SR5 TRD Tundra Challenger steps, debadged finally
http://groups.msn.com/CitizensAgainstIllegalAliens/
www.fairtax.org
Old 04-09-2007, 02:09 PM
H2O_MAN's Avatar
Yes, please use it to spread the word and protect our country from the evil witch of the north.
http://www.athenswater.com/images/NomoreClintons.jpg
Wheel Selection FAQ OKCTundra Tires and Wheels 1 12-14-2007 09:26 PM
Computer reprogrammed for tire size? maddogsvolusia 1Gen-Sequoia 5 05-12-2006 11:13 PM
Will tire size change affect towing? turnipgreen Towing 4 12-08-2005 09:28 PM
Speedo off, how do I formulate MPG w/new tire size? yfzjen Tacoma 5 11-10-2005 01:25 PM
Anyone ever try 245/75R16 tire size? v8Toilet Tires and Wheels 9 12-09-2003 10:58 AM
