P0307 Code with Check Engine Light
+ Reply to Thread
Results 1 to 10 of 10
Thread: P0307 Code with Check Engine Light
  1. #1
    Join Date
    Mar 2002
    Location
    Franklin, TN
    Posts
    3
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Default P0307 Code with Check Engine Light
    2000 Tundra running fine when I turned it off and next morning it was rough as a cobb. The OBDII code indicates a cylinder 7 misfire (P0307). Anyone had this code and was it the coil pack or sparkplug....or something else?
    I prefer to keep my hard earned dollars away from the local Yota stealership.
    Thanks
    Kent
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Mech. Engr. / Mechanic single's Avatar
    Join Date
    Dec 2006
    Location
    Tulsa, OK
    Age
    57
    Posts
    824
    Liked
    9 times
    Thanks
    0
    Images
    21
    Rep Power
    1222
    Default Re: P0307 Code with Check Engine Light
    It could be anything from a vacuum hose, injector, MAF meter, rings (compression), ECM, bad connetion, low fuel pressure. Just gotta check it out and hope it's something simple and cheap.
    White 06 SR5 DC - Blinglights bedlights
    Pop A Lock tailgate lock - TRD aftermarket LSD
    Custom Back Up Lights - Factory Fogs added
    Hellwig 7700 Swaybar - Bilstein HD shocks
    Firestone Sport Rite Air Springs w/onboard air
  4. #3
    Veteran Member integraGSR's Avatar
    Join Date
    Oct 2004
    Location
    Sacramento, CA
    Age
    33
    Posts
    1,277
    Liked
    11 times
    Thanks
    0
    Images
    14
    Rep Power
    2362
    if it is a P0307, swap the coil out to a different cylinder and see if the problem moves. if not, try moving the #7 spark plug to a different spot. if this does not work, you will have to see if the injector is firing, by using a automotive stethoscope.
    05 Salsa Red Pearl DC
    01 Honda Civic
    95 Acura Integra
  5. #4
    Supporter The Phoenix's Avatar
    Join Date
    Oct 2006
    Location
    TundraSolutions.com
    Posts
    2,495
    Liked
    4 times
    Thanks
    0
    Images
    2
    Rep Power
    142
    I'm going to say bad coil pack. Do let us know the results when you get it fixed.
  6. #5
    Join Date
    Mar 2002
    Location
    Franklin, TN
    Posts
    3
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Thread Starter
    Cleared the P0307 code...Switched the #7 coil pack with the #1 coil pack and checked the code once the CEL came back on.
    New code P0301....I love it when a plan comes together.
    Bad Coil Pack .....anyone here used Autozone or Napa coils?
    Thanks for the help.
  7. #6
    Join Date
    Oct 2004
    Location
    Sacramento, CA
    Age
    33
    Posts
    1,277
    Liked
    11 times
    Thanks
    0
    Images
    14
    Rep Power
    2362
    no problemo. they probably have the coils at cheapy stores, but remember, you get what you pay for.
    01 Honda Civic
    95 Acura Integra
  8. #7
    Junior Member mostsleek's Avatar
    Join Date
    Jun 2003
    Location
    Fort Lauderdale, FL
    Age
    30
    Posts
    459
    Liked
    0 times
    Thanks
    0
    Images
    29
    Rep Power
    12
    I would suggest using RockAuto.com, I have used them before and had great results. They have fast shipping and great prices.
    2000 Tundra Access Cab
    Survived 5 tropical storms and 5 hurricanes
    Survived a baseball sized hail storm
    Hosted numerous tailgate parties
    Water balloon refilling depot
    Served as a portable pool
    "I remember a Senator once asked me 'when we talk about CIA why we never use the word the in front of it.' And I asked him 'do you put the word the in front of God?'"
    -Richard Hayes, The Good Shepherd
  9. #8
    Join Date
    Oct 2007
    Location
    Fresno Ca
    Posts
    2
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    Alright, Im having this same problem. The diffrence is that I changed out the coil pack and also did a steptic test on the fuel injectors, they all seem to work just fine, I changed out the spark plug and also did a compression test, they all look to be fine..any more idea on what the problem is?
  10. #9
    Supporter Picasso's Avatar
    Join Date
    May 2004
    Location
    Dallas, TX
    Posts
    643
    Liked
    9 times
    Thanks
    0
    Rep Power
    249
    Quote Originally Posted by mif_slim View Post
    Welcome to TundraSolutions.
    There has been some confusion as to cylinder ID location on the 4.7L V8 as a result of both the Haynes and Chilton manuals being wrong. Can you describe where you think cylinder #7 is?
    A few people on this board have had similar problems and were initially unable to make any headway. Turned out that they were fixing the wrong cylinder.
    Once this is clarified we can move forward and give you some help.
    What is a steptic test?
    Paul
    Completed Mods:
    S&S long tube headers
    Brembo rotors
    TSB caliper upgrade
    Hawk LTS brake pads
    Stainless steel braided brake lines
    Total Chaos steering rack bushings
    Alignment to DJ's specs
    Century cap
    Line-X
    XM satellite radio module (connected to Pioneer head unit)
    Instrument cluster LED upgrade
    Future Mods:
    Rearview camera system
    BA Muffler (on order)
    Sound deadener
    Fusion Drive
    Flux Capacitor Control Unit (FCCU)
  11. #10
    Join Date
    Oct 2007
    Location
    Fresno Ca
    Posts
    2
    Liked
    0 times
    Thanks
    0
    Rep Power
    0
    I've checked the forum and I've seen that #7 is on the driver so I've checked that one. The engine runs when I take out the spark plug on #7 but when I take out the #8 then the engine stalls because Im guessing its running on 6 cly instead of 7..but of course I would like to run it on 8 like how it was intended to.
    Anyways a stethoscope is a unit sort of like a doctor thing where they use to listen to our heart, just that this one is for automobiles...which it works, I can hear the fuel running thru the injectors..its just misfiring somewhere else..
    sorry about before, i didnt spell it right and was in a rush..
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Check Engine Light?
    By vegasgreed in forum Engine, Intake, Exhaust, Induction
    Last Post: 08-20-2011, 07:14 AM
  2. synthetic oils - yes or no?
    By nhparrot in forum Engine, Intake, Exhaust, Induction
    Last Post: 06-10-2010, 03:43 PM
  3. 2000 Echo, Check Engine, P0420 code
    By TomWS in forum Out-of-Production Cars & Minivans
    Last Post: 08-16-2006, 09:54 PM
  4. Check Engine Light @ 5000 miles?
    By oldirtyhughes in forum Engine, Intake, Exhaust, Induction
    Last Post: 02-20-2004, 05:38 PM
  5. Check Engine Light
    By Kirbybus in forum Engine, Intake, Exhaust, Induction
    Last Post: 05-08-2003, 10:03 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
