Old 03-26-2007, 11:45 AM
ICON's Avatar
Dealer : Lia Toyota Of Northampton
Last Online: 11-06-2009 12:26 PM
Images: 7
ICON is on a distinguished road.
ICON's Photo Albums
Default Just got Timing Belt done...
Well, i didn't do it myself but had my regular mechanic do it. Parts were about $300 from the local Toyota dealer: water pump $99, Idler pulleys $60 each, Timing belt $43, plus coolant and o-rings. They actually wanted a lot more but i told them i can order them else where for less money and the guy matched the prices. They also quoted me $625 for labor only so i said i was all set.
For labor, it was about $315 and took him about 7 hours to do it. He didn't run into any issues and things went very smooth. Just like everyone who's done it, it's a lot of unbolting parts and moving them out of the way. The belt was changed out at 90,262 and the parts looked pretty good, pics in my gallery. The water pump was leaking just a little bit but i attribute that to a mildly failing gasket, the bearings were great and the casting showed no pitting at all. The timing belt still looked great without any cracks or abnormal wear. The idler pulleys were still tight but did have a little play so i'd be questioning whether or not they'd make it another 90K, which the parts manager at the dealer said they rarely change them in the 4.7L. Cam and crank seals looked great and weren't leaking a drop and everything else seemed ok.
The mechanic was really impressed with how well built the engine was and how quiet and smooth it was. I think he might be looking at one in the future.
'01 Tundra Reg Cab SR5 V8
'05 Honda Foreman 500S 4x4
'04 Honda Shadow Sabre 1100
Old 03-26-2007, 05:26 PM
2qik2see's Avatar
Dealer : Pohanka of Salisbury
Last Online: 11-26-2008 10:05 AM
2qik2see is on a distinguished road.
2qik2see's Photo Albums
Thumbs up Re: Just got Timing Belt done...
Excellent post ICON! This was exactly the info I was looking for! How was your valves? Did you have to tighten/adjust them any? Again, nice read!
Old 03-26-2007, 06:15 PM
Last Online: 08-22-2008 02:15 PM
4.7-4V is on a distinguished road.
4.7-4V's Photo Albums
Default Re: Just got Timing Belt done...
The valves aren't involved in any way with a timing belt replacement. You don't even take the valve covers off.
Old 03-26-2007, 07:38 PM
2qik2see's Avatar
Smile Re: Just got Timing Belt done...
I know their not involved with the timing belt change! I was just wondering if you done yours yet and if so, how was it? I need to find a good mechanic around here I can trust. The stealership is just soo dang $$$! Sounds like you got a good one!
Old 03-26-2007, 10:29 PM
Bergmen's Avatar
Dealer : Thurston Toyota
Last Online: 07-15-2009 07:07 PM
Bergmen is on a distinguished road.
Bergmen's Photo Albums
Yeah, but if you have shims under buckets like the newer V-8's have this is the time to change a shim if you have to (miserable system IMO).
The camshaft over the shim to be changed has to be removed and the only way you can do that is with all of the junk in front taken off.
JMHO
Dan
Old 03-27-2007, 07:45 AM
ICON's Avatar
Images: 7
ICON's Photo Albums
The valves were quiet so the mechanic said if they aren't making noise, don't touch 'em. He said he rarely comes across valves in Toyota's that need adjusting.
Old 03-27-2007, 11:47 AM
2qik2see's Avatar
Cool ICON! Thanks for the info. You the man!!!
timing belt and water pump taylor's 2001 Tundra Engine & Drivetrain 24 07-22-2008 11:54 PM
Timing Belt Done! doctormdds 1Gen-Sequoia 24 07-24-2007 03:03 PM
Timing belt change svxman 1Gen-Tundra 4 01-19-2007 01:16 AM
Replaced Timing Belt Last Week devo 1Gen-Tundra 6 12-27-2006 02:42 AM
When to replace timing belt on 4.7? nhparrot Engine & Drivetrain 0 03-28-2002 04:48 PM
