Heater/AC blower switch
+ Reply to Thread
Results 1 to 5 of 5
Thread: Heater/AC blower switch
  1. #1
    Veteran Member george60's Avatar
    Join Date
    Mar 2003
    Location
    Northern California
    Age
    73
    Posts
    657
    Liked
    2 times
    Rep Power
    453
    Default Heater/AC blower switch
    My fan switch for heating/cooling is working only intermitantly. I cannot run the AC without it. I turned it back and forth quickly a few times and it started working. And a few times it didn't.
    Think I ought to try some carbon tet?
    It either works or it doesn't so I don't think the resistor(s) have anything do with this.
    2003 Tundra SR5 AC V8.
    (And for those bird-dogs out there ... I did a couple of searches)
    Thanks George 60
    "... nevertheless, thou may chose for thyself ..."
    Mormon Doctrine
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Join Date
    Dec 2004
    Location
    Birmingham, AL
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Default Re: Heater/AC blower switch
    I am having the same problem with my 2000 Tundra. I have dealt with this (until I can come up with a fix) by leaving the fan in the "on" position all of the time.
    Hope someone can help us troubleshoot.
    Thanks
  4. #3
    Junior Member mostsleek's Avatar
    Join Date
    Jun 2003
    Location
    Fort Lauderdale, FL
    Age
    30
    Posts
    459
    Liked
    0 times
    Images
    29
    Rep Power
    13
    It still might be the resistor. Mine only worked on high. It was either off (at low, mid 1, mid 2) or working on high. When I took off the old resistor, I found the problem. It was a cold solder joint that broke. I thought, that I could just resolder it. However, apon further inspection the heatsink was cracked. A new one was about $40.00 from the dealer.
    2000 Tundra Access Cab
    Survived 5 tropical storms and 5 hurricanes
    Survived a baseball sized hail storm
    Hosted numerous tailgate parties
    Water balloon refilling depot
    Served as a portable pool
    "I remember a Senator once asked me 'when we talk about CIA why we never use the word the in front of it.' And I asked him 'do you put the word the in front of God?'"
    -Richard Hayes, The Good Shepherd
  5. #4
    Join Date
    Jun 2006
    Location
    Fairview
    Posts
    9
    Liked
    2 times
    Rep Power
    0
    Default Blower Resistor Location
    I have the "fan works only on high" problem on my 2000 Tundra, SR5, extended cab.
    I've removed and checked the fan, which seems to be fine. I got some pine needles out of the fan cage, which were making some noises, but other than that it works fine.
    I checked the contacts on the blower motor plug, and there is only voltage on these contacts with the switch in the high position. So, with those results and studying the schematic, I am pretty sure it is the resistor.
    PROBLEM... :der: I cannot find the B5 blower resistor. The prior post said he found a bad wire solder joint. Any clues on where that would be.
    __________________ LATER
    I found the resistor mounted in the air inlet duct work. The fusible link had opened, which is what the earlier post referred to as a bad solder joint. It must open when something heats up to much.
    So I soldered that back together as a temp fix. The heat absorbing material was disintegrating so I ordered a new resistor. The fan now works fine, so I can use it (just not on the low speed setting which would generate the most heat) for a few days until the new resistor gets here.
    Thanks for all the good information on the forum.
  6. #5
    Lurking Member nacon639's Avatar
    Join Date
    Sep 2007
    Location
    Corner Brook
    Posts
    28
    Liked
    0 times
    Rep Power
    8
    If it works only on high or certain positions i'd say resistor, but if it works sometimes on high and others but sometimes not in those same positions i'd say switch. It could be motor, but switch or resistor is more likely, unless your motor is roaring like a motorcycle...
    Hope that helps...
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. '86 Toyota P/U question... (heater/AC blower)
    By Sweetwater in forum Audio & Stereo
    Last Post: 02-20-2007, 06:19 AM
  2. Heater/AC Blower
    By hayduke in forum Electrical & Computer Systems
    Last Post: 10-19-2002, 01:41 AM
  3. Fog Light Switch
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:28 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
