This is a discussion thread titled "Magnaflow 12586 or 12256", within the 1Gen-Tundra forum, part of the Truck Forums category.
I am going to go with the single exhaust. I am planning to just swap out the muffler and keep the stock pipes. I am either going with the 12586 magnaflow which is the 22'', or the 12256 magnaflow which is the 18''.
1. How much louder in the cab is the 18'' muffler? I would like more sound outside, but do not want the noise in the cab to be bothersome to others.
2. What tip should I order with this package? I like the set up that Canada Jeff has in his pictures?
I installed the 22" and was dissapointed, then everyone said it will sound better after it 'brakes in.' It has been over six months and still not much of a rumble or growl, only a little bit better than stock. If I had it to do over I would go with 18" (but then again I would probably be complaining it is too loud...)
I installed a 12" Magnaflow weld on tip, to me it looks better than the clamp or bolt on tips. Good Luck and let us know how it works out.
Cut out the resonator you'll like the rumble better thats what I did then decided I didn't want pipes so I dumped it after the muffler.Couldn't be happier
I went with the 14" Mag part # 11226 , It isn't much louder than stock even my wife has commented how quit it is compared to the system I had on the 2000 .
I would say start with the 14" . I also had a tip put on .
SheerRockO
THAT'S THE HILLBILLY WAY
2006 Limited 4x4 ,Debadged.Westin side bars,Hellwig Sway bar, Lund Deflector ,Snug-Top Expo shell .Magnaflow 14" muffler with resonator removed.
" If I knew I was going to live this long I would have taken better care of myself " "Marriage changes passion...suddenly you're in bed with a relative."
