2005 Tundra Overdrive Problem
+ Reply to Thread
Results 1 to 8 of 8
Thread: 2005 Tundra Overdrive Problem
  1. #1
    Join Date
    May 2007
    Location
    Orlando
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    Default 2005 Tundra Overdrive Problem
    I have a fully loaded TRD SR5 Tundra with 40,000 miles. Within the last 1,000 miles the OD Overdrive is turning on and off randomly. Even when the OD light is on it may be on or it may be off. I have to monitor RPM's to determine if it is actually on or off. Many times I have to pull over and put it in park to try and turn it on.
    Does anyone know why this is happening? I'm afraid to take it to Toyota and incur a big charge to fix. It seems electronic to me, but what do I know.
    Please email me at Hedonic1@aol.com with thoughts.
    Many thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member integraGSR's Avatar
    Join Date
    Oct 2004
    Location
    Sacramento, CA
    Age
    33
    Posts
    1,277
    Liked
    11 times
    Images
    14
    Rep Power
    2362
    Default Re: 2005 Tundra Overdrive Problem
    there is a ground wire that runs up into the shifter to the OD light. for some reason, that wire is rubbing on bare metal and depending on how bumpy the road is, it will toggle the OD on or off. the fix? buy a new shifter or just take off the covers and re-route the black ground wire somewhere else and possible some black tape to secure it from future rubbing.
    05 Salsa Red Pearl DC
    01 Honda Civic
    95 Acura Integra
  4. #3
    Join Date
    Jan 2007
    Location
    Northern, WI
    Posts
    138
    Liked
    6 times
    Rep Power
    9
    I just had the exact same problem with my work truck (but it's a 99 Dodge Ram) and the local Dodge dealer replaced the output speed sensor on the transmission (had a check engine light on also due to the bad sensor). Did an oil change too and charged the company $175 total.
    Keep up the hope!!
  5. #4
    Veteran Member willy's Avatar
    Join Date
    Aug 2002
    Location
    Nevada
    Posts
    1,672
    Liked
    3 times
    Rep Power
    15
    Quote Originally Posted by Hedonic1 View Post
    Many thanks.
    Did you buy the extended warranty???
  6. #5
    Junior Member Jettix2's Avatar
    Join Date
    Nov 2004
    Location
    Midwest
    Posts
    411
    Liked
    5 times
    Rep Power
    11
    At 40k, a 2005 Tundra should still be under factory powertrain warranty 5 yr / 60,000 miles, I say to take it to the dealer
    Many thanks.
  7. #6
    Supporter Gatorman76's Avatar
    Join Date
    Dec 2005
    Location
    God's Waiting Room
    Age
    68
    Posts
    1,735
    Liked
    708 times
    Images
    2
    Rep Power
    62925
    I doubt electrical problems are still under warranty but you can ask. As stated above, it sounds like a ground issue, so may be relatively inexpensive to fix.
    "Guns are a lot like parachutes ~ If you need one and don't have one, you'll probably never need one again. Added some pics from Ireland trip to Photobucket link. 2005 reg.cab long bed. A/C, 5 sp auto, cold weather pkg. V8, 4WD, LSD, Desert Sand. LT245-75-16 Firestone Destination AT . ExtangTrifectatonneau. Rugged Liner bedliner, Lund vent visors. Classic Accessories back seat gun case, rear breather mod., Tom Tom 550XXL. Clean Breaze rear sliding window screen. Deer head antennae topper. Willie Robinson bobble head, coon tail on whip antennae, curb feelers, rocks in the hub caps, Rebel Flag on roof.
    http://s215.photobucket.com/albums/cc292/Gatorman76_photos/?
  8. #7
    J - Dogg mr4x403's Avatar
    Join Date
    Jul 2004
    Location
    Palm Desert, CA
    Age
    30
    Posts
    32
    Liked
    0 times
    Images
    5
    Rep Power
    11
    Many thanks.
    have having that same problem myself. Very weird when it happens, on, of, says on but off. Did you f d a fix? I am going to look into the ground wire.
    justin
    ...Justin
    Cheap things aren't good, and good things aren't cheap.
    www.myspace.com/mr4x403
  9. #8
    Junior Member bomber's Avatar
    Join Date
    Aug 2002
    Location
    Atlanta
    Age
    59
    Posts
    146
    Liked
    1 times
    Rep Power
    13
    I'm having the same overdrive problem on my 2001 Tundra. I can wiggle the shifter and it will go on and off. Guess I'll pull the column apart since I've been through just about every other square inch of this truck!!
    Thanks for the heads up!
    bomber
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. Replies: 20
    Last Post: 02-25-2008, 05:55 PM
  2. 2005 Tundra Double Cab Remote Starter?
    By dibble9012 in forum Electrical & Computer Systems
    Last Post: 10-05-2006, 12:15 PM
  3. Toyota Unveils Long Bed Versions Of All-New 2007 Tundra Full-Size Pickup Truck
    By Truck Champion in forum Toyota, Scion & Lexus News
    Last Post: 09-18-2006, 10:42 AM
  4. 2005 Tundra DCab - Add GBS to RS3200
    By johnrbauer in forum Electrical & Computer Systems
    Last Post: 07-06-2005, 11:41 AM
  5. Slight vibration, 2005 Tundra
    By vttesh in forum Engine, Intake, Exhaust, Induction
    Last Post: 05-14-2005, 05:45 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
