I put sloted cryo-hardened Brembo rotor on it the 5th time (after tsb failed to fix it)... not only am I at 12,000 miles since then with no problem, but the pad wear is less than half... so looks like they should work for about 25k~30k a set... much better than with the stock rotors... have a set of Raybestos PG pads already for the next time and it should help even more...
Robert
