Old 02-22-2004, 12:38 PM
Verndog's Avatar
Verndog Verndog is offline
Last Online: 10-30-2009 07:17 PM
Verndog is on a distinguished road.
Verndog's Photo Albums
Originally Posted by RoundTuit
I'm in, but I have a question. I would want the PnP harness (2004) tuned for SC and headers. However, it may be a while before I have SC + headers. If I were to get the unmapped version, I assume that since I would be paying for a custom tune there would be no time limit on when that would have to be completed. If you look at my member name, it should be obvious what I am getting at.
Also, if I were to decide later that I wanted one of the standard database maps, could I pay the $100 difference instead or $150-200 for custom tune?
IMO the best route for you would be get the mapped unit, run it then after you add headers and SC you could send in for your free retune, you likely would have to pay the price difference for the SC unit as it has to be configured different.
The SC kit has quite a bit more hardware (connectors for the injector and the pop-off valve, and a MAP sensor to provide a load based input to the Unichip so the ignition/fuel maps are based on boost rather than TPS) and a lot more wiring.
I will have to check for sure on the cost to add SC...and if you are getting sooner rather then later...then your route would be best.
Kevin
2003 Silver Sky TRD SR5 V8 4x4 Access Cab
My 69 Mach 1 Pics
Factory Options:
TRD Offroad / Limited slip / Tow package / 130 amp alternator / Temp.-compass-autodim mirror.
Appearance Mods:
PPDBillet throttle & fuse covers /Weld Outback forged billet wheels / Smittybuilt nurfs / Bullbar / Leer Legend Canopy / Line X / billet antenna.
Performance Mods:
Chromex-ceramic coated S&S autochrome headers / Custom dual H crossover 2 1/4 into Magnaflow duals- rear exit / 265 75 16 Bridgestone Revo's .....R A P S /True Flow intake / Underdrive Pulley /Hellwig anti-sway bar / Timbren load springs-rear / Wheelers 2.0 leveling coilovers / Infinity x6. / Unichip PnP
