Originally Posted by mandzach
ill bring up the dyno resuts for the s/c engines yet once again.
-where are they?
do we have any results yet? im begining to wonder why they havnt been given to Kevin to be posted by this point in time-
are the s/c guys going to have to buy these Unichips without any chart showing exact gains? If the group buy would have ended on time i guess this would have been the case cause time was up -
Kevin can we get some dyno results for the s/c guys from Jack?
p.s. am i the only one here with these concerns regarding 03-04 s/c results?
Yes...I got the full report on the SC dyno, but still haven't recieved them to post. Correct peak gain was under the 40 number going around but was respectable,and this was basically a stock truck with added SC. Now in the case of the SC trucks Jack stated the benifits (numbers) usually do go up with modified exhaust / breathing. He used a modified truck done some time ago as example with SC, ported heads, catback, headers, and some intake mods that gained around 65HP.
Also, yes I've checked back on 03 SC truck and was told thru flow rate (%) lookups he can calculate the mapping for the extra injector. I'm not sure why he went this route instead of the 03 truck that was offered, but I do believe he would only do this if he was confident in his numbers.
And yes...most everyone has already purchased the unichip without a dyno for their vehicle except the bone stock NA owners which are only a couple of.
Also...we are fortunate in being in on the ground works on this. How many other mods do you get a dyno from your exact or real close setup? None, I'm aware of....you look at one dyno for a particular truck and hope yours is similar.
Everything is covered and they're painting his office and couldn't get them out.
I will post the dyno's as soon as I get them.
Kevin
