04-20-2004, 01:08 PM
I use my MityVac. To minimize the air drawn around the threads of the loosened bleed nipples, I remove them, quickly put a turn of teflon pipe thread tape on the threads, and reinstall the nipples before much fluid leaks down my sleeve.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
