Old 06-07-2004, 07:12 PM
Mike Donofrio's Avatar
Mike Donofrio Mike Donofrio is offline
Last Online: 05-04-2009 09:43 AM
Mike Donofrio is on a distinguished road.
Mike Donofrio's Photo Albums
Originally Posted by KLS
It is always possible that the adjusters are stuck which will allow the pedal to be pushed too far and feel mushy. This should be an easy fix by freeing-up the adjuster or installing a new one.
Ken
Good point, when you do a brake job you can re-use all the hardware, just be sure to clean up the starwheels real good with brake cleaner and use anti-seize where it threads and inside of the little cup. Usually, it's the little adjuster arm that turds rather than the starwheel. Use a brake rebuild kit every other rear brake job (new starwheels, springs, levers, etc) This is a pain, but those wheels and clickers wear out over time and stop adjusting.
Failing that, you can always use the 'adjust-it-yourself' method and go in through the view port with a brake spoon to give it a few clicks every now and again. Like when you get an oil change...
PS-A bad adjuster won't just give you sloppy pedal feel on the eBrake, it will take more effort to push the pedal down during normal brake application as well. More tahn just a nuisance--this could eventually develop into quite a safety hazard...
Mike D
Lost traction? Lock it up!!! Front locker install instructions here: http://www.teddnet.com/LockRightInstall.pdf
2000 Tundra with 175,000 miles and still going!
Upgrades: PA 3" Body Lift, Powertrax No-Slip rear, Detroit ezLocker front, Fabtech/Fox front, Wheeler's AALs, TC Front Diff Drop, 16 x 8 MB Wheels, 285/75R16 Goodyear Wrangler MT/Rs, Pioneer Head Unit, Infiniti Reference speakers [front and rear], 150 W bridged amp to bandpass enclosure, 6 CD changer with IR remote, iPod mini and xm hardwired into stereo, Toyota drop in bedliner, and Tonneau cover
