Old 07-13-2004, 11:10 AM
H2O_MAN's Avatar
H2O_MAN H2O_MAN is offline
Obama lies ~ the economy dies
H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor. H2O_MAN is a superior contributor.
H2O_MAN's Photo Albums
Originally Posted by docsg
My question is this? Since the combined weight of trailer, bike, and gear will be slightly less than 2000 lbs., will I be okay w/out the transmission cooler?
YES - you will be fine.
I pull 2000 lbs. in a 900 lb trailer with another 2000 lbs. in the bed of my 3.4L V6 T100 with zero problems.
My T100 has a factory tow pkg. that does not have an "extra" transmission cooler. It works for me, I keep the OD off and change the fluids often.
Your V8 Tundra will have no problem towing your loaded bike trailer.
Keep the OD turned off and drive-on NOTE: You can run all day long pulling a trailer in OD on flat land ...
Remember when cars had only 2 and 3 speed automatic's? OD is for cruising, not working. Our trucks are designed to work with the OD turned off. Don't beat yourself up - you have a great truck. And now that you have done something (RAS) to address the soft rear springs, your truck is that much better
Old T100 items for sale
Thunder Gray Metallic
2002 REGULAR CAB - LONG BED - 4WD - V8 - SR5
TRD / Kazuma LSD made by EATON
Bilstein HD shocks
Michelin 8 ply E series radials
JBA headers
Hellwig rear bar
Line-X over the rail
2005 tail lights
OEM Door Sill protectors
TRD Off-Road front coil springs
Color matched LEER Hi-Top cap
Wet Okole Sport Seat Covers
Tinted Windows
OEM Rubber Bed Mat
OEM All-Weather mats
OEM Towing Package with Remote Transmission Cooler
