Do a search. Mine broke over a year ago and I ordered new ones from a TS sponser? I found this for my 2002 but work your way around the site for the color you need. To change them you need to ease back the door cover to get two bolts and then one screw through the glass. About 10 minutes to swap them out. FYI I think it is an UV issue with the black plastic wishbone piece. I don't know if the new ones have been improved, time will tell.
BIG link.
http://www.trademotion.com/partlocat...02&catalogid=2
Fred.
So far;
Yeasu FT-8800 Amateur Radio, Rugged Liner, DuraHitch reciever w/7 pin light plug, Fog light mod w/custom indicator, Rear seat mod, Mobil-1, Spin on tranny filter, Magnefine power steering filter, Hellwig rear sway bar w/addco links & extra bolt, Formfit hood deflector, Almost free alarm upgrade, Sequoia split three wheels W/Yokohama H/T-S, Seat belt mod, Aux backup lights, De-badged, AC in derfost mode mod, Osram SilverStars, EnergySuspension Poly/greasable front swaybar bushings, Odyssey PC1200MJT Battery, Fumoto valve, R.A.S., XM w/USA Spec. TRD 4x4 Coilovers w/Bilstiens all around... When will it end!?!?...
