Old 05-15-2002, 12:20 PM
nhparrot's Avatar
nhparrot nhparrot is offline
Last Online: Yesterday 08:35 PM
nhparrot's Photo Albums
Originally posted by Mahd
I called another dealership and they told me the same bullsh....! If I recall correctly someone mentioned something about disconnecting some grey terminal located on the side of the battery to disable the DRL's. Can someone help me out.?
The "disconnecting some gray terminal" does not work on a Sequoia, that was part of one of the methods for a Tundra.
Although a mod was documented for the Tundra and there is a TSB showing how to do it on a 2000 Tundra, no one has documented a mod and there is no TSB identifying a process for the Sequoia.
The electrical diagrams for the Sequoia Headlights w/DRL's are posted in the "Garage" Lighting & Electronics forum. From reviewing the diagrams it should be possible and may even be simple, however it would take some experimentation by a Sequoia owner to verify a method.
NOTE: The Garage forums are open to TS Supporter members and above. Subscribe to TS
~Glenn
