Old 10-15-2004, 08:59 PM
Eddie's Avatar
Eddie Eddie is offline
Moderator
Eddie will become famous soon enough. Eddie will become famous soon enough.
Eddie's Photo Albums
I don't want to sound like an a-hole,but if you want a Chevy-powered truck get a friggin Chevy/GMC truck.
Like Victor said,if you have the time and $ it's possible. You'll need to get basically every drivetrain and electronics-related component from the donor vehicle,from the wiring harnesses,ECU,and evaporative emissions hose/line/cannister if you want to be emissions compliant. I'd also find a cheap beater car to drive around while the truck is under construction.
Want to do a 6-speed swap? I have a factory V8 bellhousing available. The rest of the swap (flywheel,clutch,pedal assembly and clutch hydraulics,crossmember,driveshaft,transfer case if 4WD) is your responsibility.
