Starter / Replacement Contacts
Need some help...
V8-2wd 2001 Tundra 84k-miles... and have what I believe is a starter problem. Symptoms are solenoid clicking with each turned key and then finally a startup after 4-5 tries. I've checked the battery and have cleaned all battery terminals.
I've searched through all the other threads, and it looks like most people have narrowed this down to the starter contacts. I want to go to the dealer and ask for these contacts, but I don't really know what I should be asking for. Is it the contact internally between the solenoid and the starter? In other words, would I need to take apart the starter and replace these contacts? If so, how many are there?
Or is it the battery contact on the outside of the starter? It seems that if the solenoid is clicking then this contact would be okay? I'm just guessing...
Also, from reading the other threads it seems you have to take off the air intake manifold. I'm assuming this is just the air-filter and surrounding box? Or it is a lot more involved than this?
Any help is much appreciated. I'm getting tired of playing starter-roulette every morning before going to work...
