Old 10-18-2004, 09:05 PM
mustang67408's Avatar
KE7WLF Master of Disaster
Once the starter is out, you only have to remove the rear plate. 3 - 8mm bolts. The contacts unbolt with a 12mm wrench. Do 1 side at a time.
The armature winding you will have to remove to get to the contacts, has a ring on it, it will be black and burnt looking. Just use some fine sanding paper to scuff it nice and shiny again, go easy on it and dont take off to much copper, just enough to get it clean not spotless.
Let us know how it turns out
Eddie and i will keep our ears open.
Good luck
25 yrs with TOYOTA
