Old 10-28-2004, 09:16 PM
tamu_tundra tamu_tundra is offline
Last Online: 09-10-2005 12:10 AM
tamu_tundra is on a distinguished road.
tamu_tundra's Photo Albums
No problem:
Intake Manifold Gaskets (PN 1717150020)
QTY-2 @ $30 each (both sides identical)
Solenoid Contacts (PNs 2822650070 & 2822650080)
QTY-2 @ $8.43 each (different kit for each side)
There are two sizes of alternators used in the V8s (1.4kW & 2.0kW), but I believe the starter contacts are the same for both.
Also, there is another gasket you come across when you remove the solenoid end cover. I didn't bother replacing this as looked pretty good and seemed to just serve as a debris barrier.
I'm by no means an expert, but just to make sure things are clear... My starter was only clicking once (the solenoid hitting the armature contact)- not clicking repeatedly (like when you have a low battery).
If it's not making any noise, then maybe power just isn't getting to your solenoid? You've probably done this already, but it might be worth while to make sure you have a good connection at your battery...
Let me know if you need anything else...
