Originally Posted by nhparrot
SPECIAL SERVICE CAMPAIGN (V06) FOR 1990 – EARLY 1995 TRUCK, 4RUNNER & T100 WITH 3VZ–E V6 ENGINES
Under the Special Service Campaign Program, the head gaskets will be replaced on all the affected vehicles regardless of leakage or not, and there will not be any age, mileage or time restrictions under the Special Service Campaign.
If it was already done there will be a SSC completion label affixed to the left front door hinge post near the check strap.
This is from the SPA V06 that was sent to all people.
This Special Policy Adjustment
extended the warranty coverage for the head gaskets to 8 years or 100,000 miles
The SPA (Special Policy Adjust) is no longer honered
The SSC V06 is still active.
As a result, for a specific group of the vehicles previously
involved in the Special Policy Adjustment, Toyota is now changing the handling
procedure to a Special Service Campaign.
3VZ–E Head Gasket Special Service Campaign (V06)]3VZ–E Head Gasket Special Service Campaign (V06)
With the introduction of the new Special Service Campaign(V06), owners of late
production 1990, all 1991, 1992, 1993, and 1994 up to early production 1995 (1/90 to
10/94 production date) Toyota Compact Pick–up Truck, 4Runner and T100 equipped
with 3VZ–E V6 engines who have not received any head gasket repairs from a
Toyota dealer since October 1, 1996 will be notified to contact a Toyota dealer for
head gaskets replacement.
Here is the # to call and ask:
Vehicle owners who have previously paid for head gasket replacement will be instructed to
call the National Customer Relations Department at 1–800–404–7636 to obtain further
25 yrs with TOYOTA
