Old 11-25-2004, 09:47 AM
RoundOut's Avatar
RoundOut RoundOut is offline
Last Online: 11-02-2009 06:22 PM
RoundOut is on a distinguished road.
Send a message via Yahoo to RoundOut RoundOut's Photo Albums
Default Dry air for scuba
Originally Posted by Rlockyer
. . . If low humidity were the issue, it would be much cheaper for the military to use moisture separators and filter stacks, much as we use for scuba cylinders (our air must be VERY dry). . . .
One thing about topups... TRY to get your air at full-service stations, rather than the coin-op units at gas-only or gas/quickie mart stations. The full-service stations also run their tools and other equipment from that compressor, so they are more likely to drain the tanks every night and deliver dryer air. Who knows how well the coin-op units are maintained. I've encountered some that blew visible mist and droplets out.
Interesting. That means I am using very dry air when I air up with my Scuba tank setup. I had a hook-a-rig made up when a Scuba shop I knew of was selling a bunch of old regulators. I figured that a 20' hose on an old stage 1 regulator to fill tires was a pretty cheap alternative to getting a compressor. I can fill a bunch of tires from an 80cf tank at 3000 psi. It is pretty heavy, though.
2003 Tundra SR5 4WD Access Cab Desert Sand Mica
Performance: Bassani cat-back exhaust, K&N FIPK, JBA Headers & Y-Pipe, Goodridge braided brake lines
Working mods: Tough Country front bumper, Camburg UCAs, Daystar 1" spacer & Sway-away 2.5" front coilovers & diff. drop spacers, Offroad Solutions manual hub kit, Kartek CV boots, Deaver 10 packs, BFG AT 285/75R16s on ProComp black alloy 16x8 rims, Rhino Liner, tool box, KC Slimlights, Form Fit bug deflector, Donnelly mirror, Muth Signal mirrors, "Tundra" HD floormats, Hi-Lift, Skid Row front, middle & rear skid plates, Custom rock sliders, Custom rear bumper & swing-out tire carrier, Icom 208H, CB, Backstopper backup sensors, auxiliary backup lights, Optima Red & Optima Yellow, Painless battery isolator, Champion 10K winch, Viair 400C, 4 gallon air tank, ARB Lockers front & rear, greasable bolts & sleeves for the Deaver leaf springs, Engle MT45.
Appearance & Comfort mods: Aftermarket Leather, desert sand mirror covers, dark grey fender flares, map light mod, de-badged all emblems, all black grille.
Future: Auxiliary fuel tank, replace tailgate w/ sand ladders
