Old 12-16-2004, 05:06 PM
LGL002's Avatar
LGL002 LGL002 is online now
Last Online: Today 12:25 PM
LGL002 will become famous soon enough.
LGL002's Photo Albums
Originally Posted by richj11
I picked up this 1988 CAMRY to commute with to keep the miles off the Double Cab!
When the heater is on, there seems to be very little air flow. I have disassembled the blower, all is fine. The suction seems to be between the hood and windshield. I made sure it was all clean as far as I can see. Is there possibly something (filter?) farther downstream that could have been clogged by pine needles, etc?
Thanks in advance for any advice.
Rich J
There are no filters on either air stream side of the fan although there's usually a screen to keep the big stuff out on the intake side. If you move your control to recirc or max that bypasses the outdoor intake and draws air from inside the car which would eliminate that possibility. You also might try removing the fan again and blow compressed air both directions to see if that clears anything out. The other things to check would be any cables or linkages that operate the doors controlling air directional flow. Did you try the motor while it was out to see if all the speeds worked? Sometimes a resistor is used for motor speed and they can fail as could the switch itself. Just a couple of thought to try if you already haven't. Good Luck
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
