I have an 02' Sequoia LTD with DRL's. The resistor pack is to the right side of the battery, and disconnecting the plug does indeed make them go out. Works like a charm. I have installed a relay and switch to be able to make them go off and on as needed also.
There is a single bolt that holds the pack on to the side fender well. You might need to remove the battery so that you can reach this.
If you need I can post a few photos.
