Originally Posted by Jordansrealm
MDR Course Map
Above is a course map for one of the courses there for MDR Racing. If you want to learn more about the MDR series go to www.mdrracing.com. I attend all of their races and often chase or prerun for some friends that race. I will warn you now the course is very rough, lots of different types of terrain from sand to rock with more than your fair share of whoops. You can go slow through it but its quite rough so you know. There are also plenty of chase roads in the area which are much smoother for chase vehicles needing to get around the course fast to help their teams. Plenty of fun to be had out there if you head out sometime. When the races start up in Feb I plan on trying to organize the guys here to go and checkout some races.
Oh yeah, the course is somewhat marked but most likely most of the course marking have been removed or stolen. A week before each race MDR goes out and marks the course for the upcoming weekend. Its not hard to find the course but you may get a little turned around when you get around the back side of some of the mountains so keep that in mind. I have run this course back and forth probably 10 times in 2wd no locker and did fine just have to know what youre doing behind the wheel. I wouldnt suggest going offroading anywhere especially on a rough race course without atleast one other truck.
Matt,Shelby, Kai, Kyle, Lalo, Luigi and all other Socal guys,
We need to do this once! Sounds like a blast.
Waddaya think?
Don
2001 Tundra SR5 4x4
Mods: JBA Silver Ceramic Headers, Flowmaster 40 series single out, K&N FIPK, RAPS, ASP Underdrive pulley w/ gatorback belt, 3" Body Lift, 5" TC lift with Spindles, TW Extended Sway Away Race Runners to do away with the TC Spacer, Total Chaos Uppers, Bilstein 5100's, Deaver 11 stack, 4:56 gears with Detroit TrueTrac rear LSD, Line-X Spray In, Nitto Terra Grappler AT 315/75/16, Eagle 102's 16x10 Aluminum rims, True H.I.D. High-Low Beam, Phillips Crystal Vision 9005 Fogs, Altezza Tails, Clear Corners, Billet Grill And XM Satellite Roady 2
Future mods: STS Turbo w/FMU, Unichip, Trans shift mod and someother cool stuff.
Check out:
WWW.SOCALTUNDRAS.COM
