Originally Posted by AV8R
The dealer's on the right track with the cardboard helping. You don't want to restrict the entire radiator though. Something doesn't sound right with the temp gauge not going around 1/2 way and you said they replaced the t-stat. The other thing you can do is install a block heater for those cold mornings but that just helps get the oil temp up a little before you crank it over. Good luck with this one. Just a thought, but maybe another dealer will have a different perspective.
Yes I should have mentioned that the truck is has a soft plug engine heater, to heat the water. a pad heater on the oil pan to heat the Oil and a another pad heater on the transmission to keep it warm as well as a pad heater on the Batt. to keep it warm. I think the most of my heat is comming from being pluged in (smile). This is normal equipment for Fairbanks Alaska. The truck for the most part does not know how cold it is.
