Old 01-13-2005, 03:54 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
Originally Posted by Vu
I use 15w-40 or 20w-50 for my trucks for years now. I always used 20w-50 for my 2.7 4 cyl t-100 and it ran fine. Same for my tundra.
I switch from synthetic to regular oil all the time. Don't worry about that leak myth.
15W-50 or 20W-50 is for engines built with loose clearances or engines with clearances worn well beyond what they should be. In a tight engine I think you'll find that you'll get higher internal friction and slightly worse gas mileage with no benefit.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
