Originally Posted by fastone01
If I where you, depending on your dealer, I will report this to the dealer as excessive front brake fad and shrudder. You Platinum warranty should cover most of the brake component except under normal wear and tear components which should covers the calipers, cylinder, booster, and valves. They might not cover the rotors and pads. Once the assesment is done, see which component is covered and not, tell them about the tbs and atleast get the bigger calipers for your truck, and offer to pay for the better rotors and pads of your choosing for your year truck.
I had been to the dealer (this past Monday). They told me that they called Extended Warranty, and Extended Warranty said that those are not covered unless it was broken/not functional. Litterally I was told unless the calipers lock-up, it will not be covered. If it is locked up, they will only replace that particular caliper instead of all four. Very dissapointing !
Thanks
Chris
01 Sequoia Limited 4WD - Gibson stainless tip, Lund bug shield, glass break sensor.
95 Avalon XLS - Clarion CD player, MPC bug shield, Weathertech vent visor, ISR mod.
Both vehicles - NGK iridium, Mobil1 synthetic oil, grease & filter, Performance Friction pad.
