Originally Posted by rdrector
Ok can you help me out a little and go over removing the radio from the dash. Maybe a little off topic but since it seems as though you've done ok with it I fiqured I'd ask. I need to get to the rear of the radio; how do you remove the climate console and radio from the dash? Thanks
the climate control part of the dash is held on by clips. just insert some kind of prying device underneath and for lack of a better word PRY. hehe you can use a flat head screwdriver, a putty knife, or a small pry bar. i have a prying tool that i use which works great. after you pry it open just unplug the harnesses and put the piece to the side. then you will see 4 10mm bolts, unscrew all of them and the radio will come out. pull slightly upwards with firm pressure.
Originally Posted by TRD SyRuP
did you use the remote display?
nope.
