Old 03-27-2005, 04:09 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
More about SP Performance
http://www.sp-performance.com/SPhome.htm
Regular price for the rotors might be something like $225/pr. for the slotted and $240 for the drilled or diamond dimpled.
http://www.nationalfleetparts.com/ro...OIA&year=2003&
Performance Friction has their CarbonMetalic pads out for the 2003+ Tundra & Sequioa, #0976.20, but might not yet be in the catalog.
http://www.performancefriction.com/pages/pad_tech.htm
http://www.performancefriction.com/pages/test_data.htm
The Russell brake lines are a good fit--no problems to install, but I didn't feel a real improvement over the OEM brake lines. You'll need to bleed the air out of the rear proportioning valve very thoroughly.
I'll take rotors; I haven't decided between slotted or slotted & dimpled. I also want two litres of ATE Typ 2000 amber brake fluid. (One is more than enough for one truck.)
I presently have the ATE blue fluid in the family fleet, and about due for the 2-year change. Changing colors each time helps tell when the new fluid is throught the system. You can't find better brake fluid than the ATE (say, "ah-TAY"). I already have Performance Friction pads coming.
http://www.raceshopper.com/ate_brake_fluid.shtml
Don't the '05s have the same brakes as the 2003 & 2004s?
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
