Originally Posted by KLS
More about SP Performance
http://www.sp-performance.com/SPhome.htm
Regular price for the rotors might be something like $225/pr. for the slotted and $240 for the drilled or diamond dimpled.
http://www.nationalfleetparts.com/ro...OIA&year=2003&
Performance Friction has their CarbonMetalic pads out for the 2003+ Tundra & Sequioa, #0976.20, but might not yet be in the catalog.
http://www.performancefriction.com/pages/pad_tech.htm
http://www.performancefriction.com/pages/test_data.htm
The Russell brake lines are a good fit--no problems to install, but I didn't feel a real improvement over the OEM brake lines. You'll need to bleed the air out of the rear proportioning valve very thoroughly.
I'll take rotors; I haven't decided between slotted or slotted & dimpled. I also want two litres of ATE Typ 2000 amber brake fluid. (One is more than enough for one truck.)
I presently have the ATE blue fluid in the family fleet, and about due for the 2-year change. Changing colors each time helps tell when the new fluid is throught the system. You can't find better brake fluid than the ATE (say, "ah-TAY"). I already have Performance Friction pads coming.
http://www.raceshopper.com/ate_brake_fluid.shtml
Don't the '05s have the same brakes as the 2003 & 2004s?
Ken
Thanks for the added info and links, Ken. I like the slotted/diamond rotors. Let us know how you like the new PF pads....
Originally Posted by Ademadude1960
Hell i'm in for the front and rear cross drilled and slotted for the 04 Sequoia.
Brendon
Originally Posted by Blender
Im in for a set of slotted rotors.
Right on, Guys....!!
We have 10 people already....
I'll be confirming all pricing by Monday and will post the retail prices for the Registered members at that time...... JB
