Old 03-30-2005, 08:07 AM
pservano pservano is offline
Last Online: 01-25-2008 09:34 PM
pservano is on a distinguished road.
pservano's Photo Albums
Originally Posted by tam2tundra
same here. I have been using fram or the cheapest filter when I change my oil and have never had problems with my engines using oil or needing motor overhauls. My last car was a bmw with 225,000 miles and never used any oil or smoked. I do change my oil every 5000 miles though.
The rubber gasket has a tendency of coming apart from the filter. I purchased FRAM doubleguard brand when I replaced the oil on my Toyota Sequoia. Upon starting the truck, I discovered that I was leaking oil on the driveway. The leak was not noticeable until I started the vehicle. If you folks are going to continue using FRAM filters, ensure to check for leaks. I purchased a FUMOTO valve from Fumotovalve.com ($20.00). It made the process of changing oil easy also on my case I don't have to drain all the oil to replaced the oil filter.
2006 Dodge Ram 3500 5.9 CTD SRW 4x4 13,600 miles
2005 Toyota Camry XLE 33,00 miles
2002 Toyota Sequoia 2wd Limited. 90,000 miles.
2002 Suzuki Katana 15,500 miles motorcycle
2001 Toyota Avalon XLS. 78,600 miles.
1992 Toyota Previa. 140,000 miles.
1997 Acura Integra LS 106,000 miles.
1990 Dodge Dakota 3.9L V6. 110,000 miles.
