Originally Posted by pistolpete
is this only for the 2005 Tundra double cab...my 2004 Double Cab has two separate compartments under the seat....thus does cutting or permanent modification need to be done to fit this unit in???
The unit fits both 2004 & 2005 Double cabs. No cutting or mods needed to install. There is a wire harness that has detailed instructions for the installations. I will try to post it up for you so you can have an idea of what entailed.
Matt
