Old 04-12-2005, 07:16 PM
Jack Burton's Avatar
Jack Burton Jack Burton is offline
Jack Burton is on a distinguished road.
Jack Burton's Photo Albums
Originally Posted by auslandt
Do they offer a set of Ceramic Pads. Performance pads are nice, but dust is awful on stock. I would be all over it if they offered low dusting ceramic pads.
Hey,
I don't think they carry the ceramic pads...... You can buy the PF ceramics at your local parts store. When Hawk makes their HPS pads for the '03-'05's they would be a good semi-metallic pad w/less dust.....
How 'bout buying the rotors here..... Great prices for a top set of rotors..... JB
Here's why they don't carry the ceramic pads......
Why don't you recommend Ceramic Brake Pads?
Let's start by saying that ceramic brake pads have a place in the automotive industry. They were designed to be a low-dust, noise-free brake pad. They came into popularity after the discontinued use of asbestos-based brake pads. At that time, semi-metallic pads exhibited problems with higher noise and dust levels.
That being said, I can tell you that Ceramic Brake Pads were NEVER designed to be a performance brake pad! Some companies have done a terrific job marketing their higher-priced, ceramic pads to the consumer as a performance pad. Ceramic brake pads typically have lower friction coefficients, and act as an insulator - raising rotor temperatures in cast-iron disc systems. When you have a vehicle that has persistent braking problems- the last thing you want to do is install components that have a LOWER friction coefficient and that RAISE effective operating temperatures! See our section on how this can cause ' Warped Rotors "
Premium-grade semi-metallic or hybrid pads are more effective for handling elevated temperatures and dissipating heat away from rotors. Most, if not all, semi-metallic pads have a degree of ceramic content ALREADY IN the brake pad.
Premium-grade, semi-metallic pads can offer LOW-DUST, NOISE-FREE Performance without sacrificing stopping power and increasing rotor temperatures!
Most organizations with fleet vehicles and other extreme-service applications already know what we're telling you: High-quality semi-metallic pads offer the best combination of stopping-power and extended-wear of any brake pad type on the marketplace today!
