Old 04-15-2005, 12:10 PM
KLS's Avatar
KLS KLS is offline
KLS's Photo Albums
You need five bleeders. Three 7mm for the fronts and the rear proportioning valve. Two 10mm for the rear wheel cylinders. If I was buying only two sets of 2 bleeders each, I'd put one of the 7mm speedbleeders in the proportioning valve..it's the hardest to reach.
Ken
You get what you inspect
Not what you expect.
Gibson exhaust system
Hellwig Rear Antisway Bar
