Originally Posted by Himself
So is the brand called Form-Fit? May I know how much it costs and does it work well as a bug shield? Also, is it a no-drill install? Lastly, does it rub against the paint when you drive? I understand that some of them actually flex and when u drive, them may gradually wear the paint down.
I believe the form fit costs around $100.00. It works well as a bug shield. It is also a no drill installation. It does not rub off on the paint. It comes with 3M protectors that go on your hood with an adhesive. The bug shield vibrates on the 3M protectors. Mine does not flex when I drive. The only time I have seen it flex is when I go through a car wash. At the end when all that air is force on your vehicle in order to dry it.
