Old 05-03-2005, 03:32 PM
mustang67408's Avatar
mustang67408 mustang67408 is online now
KE7WLF Master of Disaster
mustang67408's Photo Albums
Last Online: Today 02:58 PM
mustang67408 will become famous soon enough.mustang67408 will become famous soon enough.
Originally Posted by blaketag
I've had the same thing happen several times on my '01 SR5 4WD I recently purchased used. I found several older threads that indicated topping off the brake fluid can help. Since I've done that the VSC TRAC/VSC OFF lights have not come on. My brake fluid was just below the MAX line when I topped it off. Give that a try and see if it helps. If not, it could be a bad sensor or VSC computer.
Tom
BLAKETAG: Your problem is (01 seq only) going to be the brake booster (99%) also, IF the top off didnt work. The only way to tell is to pull codes.
ATROPINE, you need to get the codes read first before we can diag more, if the topping off doesnt work. there is no way to disable it either. I dont think your is a booster problem, but rather the skid control ecu.
but without codes its only a guess.
23 yrs with TOYOTA
Discounts on Toyota Parts
K.I.S.S.
