I completed the front brake TSB as stipulated by BR004-02 with the exception of replacing the backing plate. I’ll explain what parts I purchased, how I did the work, followed by my assessment of the final results. I am currently experiencing a problem. Most of the work was done during a visit to my mother’s, who has a garage, and using jack stands and the spare tire changing jack that came with the truck. Photos of the job are posted in my gallery.
Here’s what I purchased:
- Pair of used TSB calipers (13WL), with the shorter mounting bolts, from a TS member and rebuilt them using a Toyota caliper rebuild kit. They were cleaned of rust and repainted using a spray can of Plasti-kote caliper paint.
- Akebono ProAct ceramic pads from Rock Auto
- Set of brake pad shims from Toyota
- 1 pair of cryo’d PowerSlot rotors from
tirerack.com
- Set of Goodridge stainless steel braided brake hoses from Wheeler’s Off Road
- Set of brake tubes, 1 for each caliper, from Toyota
- Set of stainless steel Speed Bleeders (3 x 7mm, 2 x 10mm bleeders)
- Valvoline Synpower brake fluid
Here’s what I did and how I did it:
1. I prepped the install first by removing the calipers and rotors in order to trim the backing plates so that the new calipers would fit.
- The rotors had to be knocked off from behind with a small sledge hammer the first time I removed them due to the tight fit and the small amount of rust between the rotor and the hub.
- The trimming of the backing plates was relatively easy. I held up the new caliper to the plate to mark the areas that needed to be cut and then went about cutting them with a combination of tin snips and a Dremel with a cutting wheel attachment. I filed the cut edges and then coated them with a small bead of JB Weld for corrosion resistance and to cover any sharp edges.
- All of the above was done on the first day after which I reinstalled everything so that I could drive to work the next day. The final prep and then instal was done over a two day period about two weeks later.
- The hubs were cleaned of as much rust as possible using wire brushes, naval jelly and sand paper. I gave the hubs a coating of WD-40 to retard the reformation of rust.
2. The installation of the new calipers, pads, and rotors was fairly easy and very straight forward.
- The new rotors slipped on with more clearance between the rotor and hub than I liked. Very different fit than the originals that had to hammered off and on during prep.
- The calipers with the pads installed were slipped over the rotor and bolted on without a problem.
- The Goodridge brake hoses were not installed because the front hose fittings were too shallow, so I reused the stock hoses. I go into more detail about this in this (
Stainless Brake Lines) thread.
- The brake fluid was sucked out of the reservoir with a turkey baster and all five Speed Bleeders were installed. During the flushing of the brake fluid, I discovered that the 10mm Speed Bleeders in the rear brakes were too short and would not seat, so I reused the stock bleeders. I go into more detail about this in this (
Speed Bleeders) thread. The old brake fluid had the color of dark apple juice and I have no record of it ever being changed during the life of the truck. The new brake fluid is almost clear.
- Completed the install by testing the lines for leaks and then remounting the front wheels.
The results of this install:
1. The first day and half, the pads were clearly not providing much stopping power at speeds higher than 30mph and I thought this had been a tremendous waste of time and money. Additionally, there was quite a bit of pad material caking on the rotors. Akebono’s web site, and the box that the pads came in states that they do not need any braking in, so I didn’t bed in the pads. Does “break in = bed in?” I then followed the directions that came with the PowerSlot rotors and did six 40-5mph bed in runs. The rotors cleaned up completely and the pads grabbed like a vice grip. My gallery has pictures of the rotors before and after the bed in.
2. THERE IS CURRENTLY A PROBLEM with the front brakes. While driving the truck, they feel like and are in fact dragging. When jacked up, the front wheels still rotate but will do so for only 3 revolutions before stopping after giving them a good spin. When I take the wheel off and pull the pads away from the rotor and push the pistons back into the caliper, the wheel spins freely again. The moment that I start the engine and apply then release the brakes, the condition returns. It is possible that this may improve with additional bed in runs but I am not sure. I’ve driven a few hundred miles with this condition with no ill effects and the fronts don’t seem to get much hotter than before. The rear brakes aren’t dragging, but the shoes may not be in good enough condition for them to be able to drag. ANYONE HAVE AN IDEA AS TO WHAT IS HAPPENING OR HOW I SHOULD TROUBLESHOOT THIS?
3. Braking is very smooth and controlled, and the pads are silent. I can brake firmly from high speeds with both hands off the steering wheel and my truck will continue straight with no deviation. There’s also no more shaking at high speed.
4. The brake pedal feels no firmer than before but the stopping power has drastically improved. My truck has more of a tendency to nose dive now, so I’m going to have to clean up the rears to try to even out the front/rear braking.
Final Notes:
- The head of the bolt, that secures the left bracket holding the attachment point for the brake tube and the brake hose, twisted off when I tried to unbolt it. It twisted off very easily and there was a lot of rust on the 2 threads that came off with the head. It took more time to fix this than it took to install the rotor, caliper, and flush the brake fluid. Had the hardened steel extractor bit not broken when I tried to remove the remaining portion of the bolt, it would not have taken quite so long. Most of my time was spent grinding out the broken extractor bit with my Dremel. This was followed by drilling and tapping the hole to remove the bolt remnants, which were solidly rusted on. The new bolt went in with a lot of antiseize.
- After seeing how little of the backing plates needed to be trimmed for the new calipers to fit, I would much rather have this done than to have the spindle removed and the bearing replaced in order to have a new backing plate installed per the TSB. Some people have incorrectly stated that the old bearing is replaced with a redesigned one. The TSB clearly shows that the Old and New bearing part numbers are identical.
- I noticed that the old (D812) and new (D976) pads have almost identical pad contact area. A few people have alluded to the new pads having a greater contact area to help reduce overheating the rotors. A comparison of the two contradicts that.
- My intent for doing this was to resolve the front brake vibration and to eliminate rust and corrosion as best as I could so that I never have to deal with either of those for a long time if ever again. If I can get the front brakes to stop dragging, I’d be one happy camper.
This was definitely a very good learning experience. I can’t say at this point how effective this is compared to just replacing the pads and rotors for those with 00 - early 03 Tundras and have not had the TSB done. After a few hundred more miles, I’ll try to remember to provide an update.
Paul
