Old 06-21-2002, 12:49 PM
dyogim's Avatar
dyogim dyogim is offline
SAS'ed #5
dyogim's Photo Albums
Originally posted by mswaz
---LONG---
The Line-X was $375 and it loks good but am not happy with it at all. It seems to be put on very thin. They sprayed over the rubber drain holes after they said they would tape them up. And now my truck has some type of overspray over the entire cab and front end. I think I probably just chose the wrong Line-X dealer.
Other than that it looks good though.
I think you went to a shady dealer who does half-a$$ jobs. I would go back and get it cleaned up. If he doesn't, go to corporate.
My dealer asked if I wanted the drain plugs in or out, bolts sprayed over or taken out, he made sure everything was the way I wanted it. I figured if I have any problems with water draining, I can drill some holes into the plastic plugs without worrying about rust. Also, there's a gap at the front of the bed where the water can drain.
I've been very happy with Line-X. $375 was the total for the over-the-rail spray on. Plus the $20 off coupon you can print from line-x.com.
Mike
http://dyogim.blogspot.com
