I would change all the lugs with new ones since they might be cracked already. So, don't drive the truck. To get the lug that snapped, you will have to drill a hole in the lug and screw in a "plug" that screw in counter clock wise and once you get it tight you can release the broken lug nut out by continuing to move it in a counter clock wise direction. Might have a professional do that once you get all the other lug nuts replaced if you don't have the tools to do that.
