Old 07-19-2005, 12:38 AM
lharrell79 lharrell79 is offline
Last Online: 03-15-2007 09:55 PM
lharrell79 is on a distinguished road.
lharrell79's Photo Albums
Originally Posted by toy05
Thanks for the reply. So these aren't a press fit into the back of the hub ?
Just check the back of the hub. You should be able to tell right away if it is a press in stud. You will see the back of the stud on the back of the hub. Any brake or muffler shop should be able to change all the studs out for about 20-50 bucks depending on where you take it. If they are press in, you will need a shop to do it, unless you have a good pnuematic press in your garage.
Lucas
