Old 07-19-2005, 01:19 PM
Picasso's Avatar
Picasso Picasso is offline
Last Online: 02-23-2008 04:39 PM
Picasso is on a distinguished road.
Picasso's Photo Albums
Default Lug Stud Damage
Originally Posted by toy05
This makes me ill , but has anyone replaced a front lug bolt on a 05 4x4 DC ?
At 5k miles tonight, I rotated my tires. Glancing at the manual for the torque values , I set my torque wrench to the what I thought was the right value of 110 ftlbs. My last truck was a Chev 1 ton dually with a torque value of 140 ftlbs so this didn't seem unreasonable at the time. As I finished the last lug, it snapped ! SH*T ! I checked the manual again and realized it should have been the 83 ftlb value. I backed off the remaining 5 and retorqued to the 83 ftlb.
I can't imagine that your torquing of a stud to 140 ft/lbs alone broke it. Something else must have contributed to its failure before you touched it. Maybe it was defective.
The point I'm trying to make is that it may not be necessary to replace the other five studs simply because they were torqued to 140 ft/lbs. Since it is not known why this stud failed, and if it makes you feel more comfortable to replace the others, then go for it.
Good luck.
Completed Mods:
S&S long tube headers
Brembo rotors
TSB caliper upgrade
Akebono ProAct ceramic pads
Stainless steel braided brake lines
Total Chaos steering rack bushings
Alignment to DJ's specs
Century cap
Line-X
XM Commander satellite radio w/USA Spec dual aux input adapter
Future Mods:
Rearview camera system
Sound deadener
Fusion Drive
Flux Capacitor Control Unit (FCCU)
