Old 07-19-2005, 01:26 PM
Picasso's Avatar
Picasso Picasso is offline
Last Online: 02-23-2008 04:39 PM
Picasso is on a distinguished road.
Picasso's Photo Albums
Default Moot Point
Originally Posted by toy05
All done guys ! Thanks for the suggestions. Hope this helps someone else someday. I bought 6 of the little buggers from Toyota for $3.46 a piece. Replacement was simple:
Pull wheel
Remove two caliper mounting bolts and support caliper
Remove rotor
Two taps with a small hammer and each were out
Slip in new bolts and hand tighten until gap between bolt and back of hub closes
Mount rotor
Mount Caliper (need to find actual torque value for those bolts)
Mount Wheel and slowly suck up any slack remaining
Torque to 83 ftlbs
Not to be paranoid, but would you guys be worried about using the old acorn nuts?
Thanks again guys !
AL
I was to slow in typing my previous post. The point is moot.
I am surprised that you got the studs out so easily.
If the the acorn nuts thread over the new studs easily, then they should be fine.
Completed Mods:
S&S long tube headers
Brembo rotors
TSB caliper upgrade
Akebono ProAct ceramic pads
Stainless steel braided brake lines
Total Chaos steering rack bushings
Alignment to DJ's specs
Century cap
Line-X
XM Commander satellite radio w/USA Spec dual aux input adapter
Future Mods:
Rearview camera system
Sound deadener
Fusion Drive
Flux Capacitor Control Unit (FCCU)
