Originally Posted by sequoiasoon
Why does this not sound right to me? If your taking parts off the suspension it has to affect the geometry correct?
Changing the balljoints does not affect steering geometry whatsoever. The only way that it would affect your alignment is if they had to remove your tie-rod ends or changed the angles of your control arms, which they aren't.
No alignment is necessary after the recall work is performed.
