Old 08-25-2005, 08:48 PM
rayman's Avatar
rayman rayman is offline
Last Online: 10-22-2009 11:19 AM
rayman is on a distinguished road.
rayman's Photo Albums
With that weight, a weight distribution hitch is probably the way to go. I have a 2002 Tundra access cab 4x4 and tow a Sunline travel trailer that is just under 4000 lbs dry. If I move it around at home without the weight distribution hitch and bars, it will sag noticeably in the rear. I also have a small lift consisting of Donahoe coil-overs in the front and add-a-leafs in the rear. And don't forget the electric brake controller if you trailer is so equipped. Most important, make sure you are not overloading your trailer. Good luck.
2002 Tundra Access Cab SR5 V8 4x4 TRD Donahoe Racing adjustable coilover shocks, Total Chaos Fabrication 1” Diff. Drop Spacer, Bilstein 5100 Series shocks, Downey add-a-leafs, Mickey Thompson 16X8 Classic II wheels, Mickey Thompson LT265/75R16 Baja Radial MTX tires, Cooper LT265/75R16 Discoverer M+S tires (for winter), K&N air filter, Westin Signature Series Step Bars, A.R.E. MX Series truck cap, LINE-X spray-on bedliner, AMP Research Bedxtender, DuraHitcH trailer hitch, Warn front receiver, front tow hooks, Auto Ventshade Ventvisors, Husky Floor Liners front & rear, General Lee 10 Meter radio, Astatic mic, Nemarc M-1S CB Console, Wilson 1000 CB antenna
2003 Sunline Solaris T-2363 Basically stock
