Old 10-16-2005, 01:43 AM
Johnnny Rock's Avatar
Johnnny Rock Johnnny Rock is offline
Last Online: 09-22-2009 05:08 AM
Johnnny Rock is on a distinguished road.
Send a message via AIM to Johnnny Rock Johnnny Rock's Photo Albums
Originally Posted by Steve97TT
I had that problem once after I had the battery disconnected. Actually, I noticed my rear wiper wasn't working and then I realized my rear window wasn't either. I got my multimeter out, checked a bunch of fuses, and jiggled the rear wiper.
To my surprise mine started working again in the middle of my troubleshooting (so I have no idea if I did something or if it was coincidence.) If you figure out what gets yours going please do share.
Steve
P.S. I suspected that the window wouldn't operate when it thought the rear wiper was not in its proper resting spot. If a fuse isn't blown I'd start at the rear wiper.
Yeah, If that rear wiper is not in it's proper resting place the rear window won't work and your rear defogger won't work either witch is connected to your heats side views. I also read that if you disconnect the battery you have to push and hold the rear window button to make the window go down and hold it pushed for an extra 10 seconds. Then do the same going up, Push the up button and hold it for an extra ten seconds once the window is all the way up. This resets something with the rear window. I read about it somewhere on this site.
I just wish Toyota put the heated side view mirrors on it's own button instead of having it on the same switch as the rear defogger. I put the darkest tint you can find over the factory tint on my rear window so I don't look out it much wile driving because you can't see much threw it any way. So, I never use the rear wiper either. I depend on my side view mirrors and my back up camera for everything. So, the heated side view mirrors are VERY important to me but, I don't need the rear defoggers on at all. My Highlander has a separate switch for the heated mirrors, I wish they did the same for the Sequoia's. Johnnny
2004 Ford Lightning (Sonic Blue)
2003 Cobra with LOTS of work : ) (BLACK)
1996 Cobra (White)
1999 Tacoma 4 wheel drive (Purple in Color)
2002 Tundra Limited (Dark Green or Jade In Color)
2002 Chevy Corvette Z06 (Candy Apple Red)
2003 HighLander Limited (Silver In Color)
2005 Sequoia Limited (Phantom Grey)
