Old 11-04-2005, 05:17 AM
wkl2546 wkl2546 is offline
Last Online: 02-26-2009 09:29 AM
wkl2546 is on a distinguished road.
wkl2546's Photo Albums
Default CR Laurence Power Rear Sliding Window
KEN/JACK: Good job on this GB.....You've negotiated some fairly decent prices too (considering what these units cost on the "open" market). I believe that anyone who gets one installed will not regret it! I know I have thoroughly enjoyed mine since I installed it in 2001.
MR SMITTY: Unfortunately, only the Tundra offers a "power rear sliding window" as a factory option, hence, Toyota only makes an OEM switch designed specifically for the Tundra. Tundra's are "unique" in this respect because our "Combination Switches" (i.e. Foglight, Clutch Cancel, etc) have a
"different" physical appearance (e.g. sort of like a "canted oval" shape...).
(Follow KEN's link and you see exactly what I mean). From what I've been able to figure out, the Tacoma's don't use these type switches; their switches are more the "conventional" "straight horizontal or vertical" type. When you get your slider unit though, the CR Laurence unit will also come with a "prewired" switch for you (I've posted a pic in my photo section of what the switch should look like. It is not an exact photo of the switch that will come with your unit, but it is very close to what it looks like). Also, in the instruction manual you'll get, CR Laurence will provide you photos of
"recommended" mounting locations for the switch and a mounting template.
Again, my experience with this unit is based on my 2000 Tundra; not a Tacoma. However, I don't think there will be a hugh difference from the Tacoma (In addition to having a CR Laurence in my 2000 Tundra, I also had
a CR Laurence Power Slider installed in my 1994 Toyota Pick-Up...). IF Tacoma owners do in fact have a "blank space" that will accept a Tundra switch, there should be no reason why they can't do this modification to install an "OEM Power Rear Sliding Switch", however, I don't think the Tacoma
does.
Hope this info helps............
Bill
2000 TUNDRA-LIMITED-4X4-ACCESS CAB (7838C):
All Weather Guard Package; Prem 3-in-1 Combo with 6 Disc Changer; TRD Off-Road Package with 16X7 5-Spoke Aluminum Alloy Wheels; Leather Package; RS3000 Deluxe Security System; Running Boards; UTR Bedliner | Towing Package w/Class III Receiver Hitch
MODS: [SIZE="1"]ASC 925 Sunroof | Power Tailgate Lock | Muth Signal Mirrors | CR Laurence Electric Rear Sliding Window w/OEM Factory Switch | 2003 Center Console Upgrade | "Form Fit" Bug Deflector | G2 El-Glo White Face Guages | Front and Rear Door Sill Protectors | TRD Oil Cap | Sportmasters Tonneau Cover | Alteeza-Style Tailights | Clear Front Cornering Lamps | Sylvania Silverstar Headlight Bulbs | "TRD" Aluminum Billet 3rd Brakelight Cover | 16X8 "Ivan Stewart" Aluminum Alloy Wheels | Total Chaos Front Steering Rack Bushings upgrade | Hellwig Rear Anti-Sway Bar | Grillcraft Front Grill | Donnelly Auto Dimming Rear View Mirror W/Compass-Temperature - Map Lights | Weather-Tech Rain Deflectors | Heizgerat Setz II Heated Seats
