Power Rear Sliding WIndow
A complete set of instructions should be enclosed with every unit.
Unless you are a "glass installer" by trade, I don't think that you want to tackle the install of the window on your 2005 Tacoma yourself! Not being
familiar w/Tacomas (however, if you read the complete description of each
model slider in Ken's post...), it appears as though the 2005 and newer Tacomas, as well as the Tundras all use the "bonded in" type of rear window. As such, you need specialized experience and tools to remove and install these type of windows. Conversely, it appears as though the 2004 and older Tacomas use a "gasket type" of rear window, whereas you "maneuver" the old gasket around the window frame out of the opening, plase the new unit into the new gasket channel and then "maneuver" the assembly back into the opening (this is how it was on my 1994 Toyota Mini Pick-up...of which I did that CR Laurence Power Slider install myself....).
vr,
Bill
2000 TUNDRA-LIMITED-4X4-ACCESS CAB (7838C):
All Weather Guard Package; Prem 3-in-1 Combo with 6 Disc Changer; TRD Off-Road Package with 16X7 5-Spoke Aluminum Alloy Wheels; Leather Package; RS3000 Deluxe Security System; Running Boards; UTR Bedliner | Towing Package w/Class III Receiver Hitch
MODS: [size="1"]ASC 925 Sunroof | Power Tailgate Lock | Muth Signal Mirrors | CR Laurence Electric Rear Sliding Window w/OEM Factory Switch | 2003 Center Console Upgrade | "Form Fit" Bug Deflector | G2 El-Glo White Face Guages | Front and Rear Door Sill Protectors | TRD Oil Cap | Sportmasters Tonneau Cover | Alteeza-Style Tailights | Clear Front Cornering Lamps | Sylvania Silverstar Headlight Bulbs | "TRD" Aluminum Billet 3rd Brakelight Cover | 16X8 "Ivan Stewart" Aluminum Alloy Wheels | Total Chaos Front Steering Rack Bushings upgrade | Hellwig Rear Anti-Sway Bar | Grillcraft Front Grill | Donnelly Auto Dimming Rear View Mirror W/Compass-Temperature - Map Lights | Weather-Tech Rain Deflectors | Heizgerat Setz II Heated Seats
