Old 11-04-2005, 10:35 AM
wkl2546 wkl2546 is offline
Last Online: 02-26-2009 09:29 AM
wkl2546 is on a distinguished road.
wkl2546's Photo Albums
Default CR Laurence Power Rear Slider Group Buy
HELPFUL HINT FOR THOSE JOINING IN THIS GROUP BUY
Although my hint is based solely on my experience on installing my CR Laurence Power Rear Slider in my 2000 Tundra, I would guess that the same basic "principle" would also apply to the Tacomas. HELPFUL HINT: Just before you have your rear slider installed, go ahead and remove the rear seat assembly (on the Tundra, the rear seat back and seat cushions will come out as one whole unit...) before you send your truck to the installer and just store it in your garage. This will eliminate one step that your installer is going to have to do anyhow AND (if your installer puts it back in after the window is installed...) you'll just have to turn right around and pull it back out again when you go to mount the motor unit and run the wiring. Might as well do it once, right up front, and "everybody can be happy".....
Just some friendly advice.............
Bill
2000 TUNDRA-LIMITED-4X4-ACCESS CAB (7838C):
All Weather Guard Package; Prem 3-in-1 Combo with 6 Disc Changer; TRD Off-Road Package with 16X7 5-Spoke Aluminum Alloy Wheels; Leather Package; RS3000 Deluxe Security System; Running Boards; UTR Bedliner | Towing Package w/Class III Receiver Hitch
MODS: [SIZE="1"]ASC 925 Sunroof | Power Tailgate Lock | Muth Signal Mirrors | CR Laurence Electric Rear Sliding Window w/OEM Factory Switch | 2003 Center Console Upgrade | "Form Fit" Bug Deflector | G2 El-Glo White Face Guages | Front and Rear Door Sill Protectors | TRD Oil Cap | Sportmasters Tonneau Cover | Alteeza-Style Tailights | Clear Front Cornering Lamps | Sylvania Silverstar Headlight Bulbs | "TRD" Aluminum Billet 3rd Brakelight Cover | 16X8 "Ivan Stewart" Aluminum Alloy Wheels | Total Chaos Front Steering Rack Bushings upgrade | Hellwig Rear Anti-Sway Bar | Grillcraft Front Grill | Donnelly Auto Dimming Rear View Mirror W/Compass-Temperature - Map Lights | Weather-Tech Rain Deflectors | Heizgerat Setz II Heated Seats
