Thread: Safety Recall!
  #261 (permalink)
Old 11-05-2005, 12:23 AM
mustang67408's Avatar
KE7WLF Master of Disaster
No they dont change the bolts. It says in the SSC
If the sizes of the bolt heads are 17
mm, lower ball joint replacement is
NOT NECESSARY
. Proceed to
section
“VIII. SSC COMPLETION
LABEL INSTALLATION”.
If the sizes of the bolt heads are 14
mm, replace the lower ball joints
using part
04005-21134. Proceed to
section
“VII. WORK PROCEDURE”.
The vehicles w/17MM bolts have already been updated at the factory. They are the later model tundras and SEQ's. You have to check the VIN's and inspect the ball joints for production dates, in order to determine which is the correct joint for that particular vehicle, IF IT NEEDS IT.
Hope this clears it up.
Yes, they should have come with new bolts too.
25 yrs with TOYOTA
